I can't use my epson TX111 scanner. when i try to start to scan something this msg appear: "The Twain driver returned an unkown error code". I'm using windows7, coreldraw x5 & adobe photoshop cs 4. What should i do? Thanks
4 Suggested Answers
  • 167 Answers
SOURCE: cannot operate scanner
pls check if a software like smarthru4 is bundled or not??
omnipresent
Posted on Oct 26, 2007
  • 3 Answers
SOURCE: EPSON CX3810 "scan cannot be started" error
I suggest scan from MS Paint first - if this works proceed to step 1, if not, proceed to step2.
Step1, check device manager - update driver.
Step2, check if there are other scanner installed or software installed under C:Windows/twain_32 folder. Delete any files there except for wiatwain.ds and folders that has "e" at the beggining. Re launched Epson Scan. If it fails check step3.
Step3, trash and reinstall driver, you can download the driver for this on the epson site, www.epson.com, select your regio of course, go to drivers and support, select your product and select the appropriate system that your using.
Step4, Optional step, on the properties of Epson Scan (you'll see this if you right click Epson Scan icon), make sure that the compatibility corresponds to your system, you'll see a check box there that says "Run with..."
If this steps fails, perform registry adjustment by removing Epson Scan software under the HKEY_CURRENT USER and HKEY_LOCAL_MACHINE, reinstall software again.
Posted on Mar 18, 2009
  • 6 Answers
SOURCE: nrg scanner , type161 TWAIN
in the hospital
Posted on Feb 03, 2011
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Epson Perfection v200 stopped working on my imac
Try to scan using epson scan to isolate the issue. You can launch epson scan from applications. If you can scan using epson scan, call adobe to troubleshoot further on photoshop.
If you get an error epson scan cannot be started or if it won't launch. It could be connection or driver issue.
To uninstall/re-install twain on mac, follow the instructions:
- go to applications. Trash epson scan and epson scanner monitor
- Go to library then application support. Trash epson scanner module.
- Go to library then image capture. Trash twain data sources.
- Go to the hard drive. Click on user. Click on the name of your computer. Click on library. Click on preferences. Click on epson. Trash epson scan.
- Empty the trash.
- Restart your mac.
- Log on to support.epson.com. Type in v200 in the search box on the top right corner of the page then click search. click on the first search result. Click on the drop down box and select macintosh operating system instead of windows. click on the second driver down, epson12527.dmg then click on download now. Select no thanks, i prefer not to receive this information then click accept. Install the epson scan installer after the download.
- Then try to scan using epson scan.
If epson scan won't launch or you get an error, try a different usb cable.
Goodluck.
sherlyn c.
P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; } P { font-family : Verdana, Geneva, Arial, Helvetica, sans-serif; font-size : 10px; } .boldBlue { color : #2A57A5; font-weight : bold; } .qatable { width : 390px; }
May 21, 2009 | Epson Perfection V200 Flatbed Scanner
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
May 03, 2009 | Epson Perfection V500 Flatbed Scanner
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to epson.com. Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
I cannot open my scanner instead this appears:"escndv.exe has enc
try downloading and installing the copy utility v3.3. usually nost espon hardware need more than one driver to work properly. my printer needed 3 drivers...
Apr 16, 2009 | Epson Perfection 3590 Photo Flatbed...
I have an Epson Perfection 3590 Photo and when I tried to open it this appears:"escndv.exe has encountered a problem and needs to close. Sorry for the...etc." I have already downloaded the Epson Scan...
This file that cannot be found "DICElib.dll" is actually installed by the LaserSoft SilverFast driver that comes with both scanner models. This file gets placed in the Epson Scan folders during installation because the LaserSoft SilverFast Driver works in conjunction with the Epson Scan driver for communication to the scanner. The solution to this issue is to uninstall and re-install the LaserSoft SilverFast Driver and NOT the Epson Scan driver.
On the "Start Here" poster it says that you have to install the Epson scan driver first before installing the LaserSoft SilverFast. Other possible causes are that the file has become corrupt, has been moved or has been deleted.
If this will not work, please call epson technical support. They have troubleshooting steps for that type of issue that cannot be disclosed here.
Please let them know if you have any other scanners or digital cameras installed on your system. If so, provide the model and manufacturer.
Sherlyn C.
Apr 16, 2009 | Epson Stylus CX6000 All-In-One InkJet...
EPSON STYLUS CX4800
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=58606&prodoid=56291067&infoType=Downloads&platform=Macintosh
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus DX4450 scan macintosh problem
Trash and re-install the drivers.
To uninstall the drivers:
- trash epson scan and epson scanner monitor from applications.
- go to library, then application support, then trash epson scanner module.
- go to library, then image capture, then trash twain data sources.
- go to the harddrive. Then to users, then click on the name of your computer. Then click on library, then preferences, then epson, then trash epson scan.
Then log on to epson.com and get the compatible driver for 10.5.6. Install it on your computer.
Jan 26, 2009 | Epson Stylus Multifunction Inkjet Printer/...
157 people viewed this question
k24674
jasbo
jasbo
