Question about Mitsubishi WD-62525 62" Rear Projection HDTV
My screen turns on but it is very dim. lamp light is not flashing. I tried adjusting brightness settings to the manufacturers settings and its still dim
    Problem Solver:
  • 5 Answers
Its time to buy a new lamp.
Posted on Jan 30, 2011
Dell latitude lcd screen lamp dims
It could be 3 things:
1) Windows settings:
  • Click "Start" and then "Control Panel."
  • Click "Power Options."
  • Click "Choose when to turn of the display" located in the left-hand sidebar of the Control Panel interface.
  • Set "Dim the display" to "Never" for "On battery" and "Plugged in" and then click "Save."
2) Ambient light sensor:
Some latitudes come with an ambient light sensor which automatically changes your brightness depending on ambient light. Toggle it on/off by holding down the Fn key and then pressing the Left arrow key.
3) Brightness turned down.
Latitudes all have adjustable brightness, press the Fn key plus the up/down keys to adjust. Some old latitudes have this setting on the F5/F6 keys instead of up/down. Look for blue icons that looks like lit and unlit suns.
If the above fail, your CCFL (Cold Cathode Florescent Lamp) tube in your screen is possibly going bad. They are $10-$20 on ebay and pretty easy to replace. Just search for "CCFL" on ebay and include the exact latitude model you have. All CCFL tubes use the same power, just the length matters, but people on ebay include model numbers so you can be sure it will be an exact fit with your laptop.
Replacing the CCFL is easy, you will need a phillips screw driver, and possibly a shim/flat-head screw driver, that's it. Just watch a related youtube video by searching for "how to replace ccfl latitude" for a number of good step-by-steps.
Dec 01, 2013 | Computers & Internet
Tv comes on then picture goes out but still has sound but no picture
Sounds like a back light failure. To verify this, turn on the set, dim the lights in room. Shine a bright flash light on the screen, if you see a faint picture on the screen, you have a back light failure. You either have a blown back lamp, 24v circuit fault, or a failed inverter board.
Dec 16, 2012 | Sony KDL-32M3000 32 in. LCD Television
I have a 46" Samsung LCD tv that won't turn on. When I press the power button you can hear the chime sound it usually makes and you can hear the relay click and the screen flashes quickly then goes bl
sounds like you have a back light problem. To verify this, turn on the set, dim the lights in the room, and shine a bright flash light on the screen. If you see the faint picture on the screen, you have a back light problem. You could either have a shorted inverter that is pulling down the 24vdc line, a blown CCFL back lamp, a high voltage short (arcing) from one of the inverter outputs, or a faulty 24vdc power supply
Dec 09, 2012 | Televison & Video
Mytouch 3g slide screen doesnt light up
I have the same model but 4g. I often notice the same problem, but once i step out of the full sun/bright lights, i notice that it is infact dimly lit. This can be adjusted by opening settings > display > brightness > turn off automatic brightness and set the level to at least %50.
now, if your screen is literally too dim to see, try this : Press the power button quickly, now unlock the screen by sliding your finger from the bottom center up to the top center and releasing, all in one fluid motion. This is the default screen-lock gesture and the brightness, if this is indeed the issue, should go up one notch upon unlock. From there, follow the above procedure to turn up the brightness.
hope that helps
Sep 11, 2012 | HTC Black Mytouch Slide 3g Tmobile...
19 inch lcd monitor has dimmed display
tried to adjust in the screen set up menu the brightness and contrast. if can not get with adjustment with very dim display replaced the back light ( cold cathode lamp).
Jul 22, 2012 | Computers & Internet
LG 42LK 450 screen dims at night
The has a light sensor on the front trying to adjust brightness when brightness or light changes in the room.
Look in the owner manual to see if it can be switched off.
Apr 02, 2012 | LG 42LC42 LCD-TV 42 in. LCD TV/HD Combo
My Eiki lc-xb33 is projecting the image from my computer very dimly. Although the image is in focus, it is very difficult to see the image at all because it is so dim. Even the blue start up screen is...
You need to remove the cover and check where the lamp light is being attenuated in the optical path from the lamp to the front lens. I would try using a 12volt 50W halogen lamp in place of the real lamp and shine it into the optics system, and see where the brightness starts to go bad.
May 11, 2011 | Eiki LC-XE10 Projector Multimedia...
Screen is dim. Have brightness turned up to max setting. Does the lamp get dim with age? Mitsubishi WD-Y577 dlp rear projection tv
Yes... from the moment the lamp is put into service, it begins to deminish in brightness. You should order a replacement lamp to have on hand.
Mar 15, 2010 | Mitsubishi WD-Y577 Television
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
180 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
