Question about Whirlpool Duet GHW9150P Front Load Washer
Water will not drain from tub. Service technician today, found debris in the filter, cleaned it out (there was debris) seemed to worked, then I tried a load tonight and guess what, same problem (panel reads F 2), I checked the filter again but it was clean as well as the drain hose. No water dispensed. Is this a PUMP problem? Are parts available from big box stores like Home Depot or Lowes? Next time service technician can come out is January 5th. frustrated Mike.
    President:
  • 1,554 Answers
It sounds like a pump problem particularly the impeller. Water cannot be drained out with the impeller broken or restricted. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Posted on Jan 01, 2011
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The Whirlpool have a new pump design since they have been having problem with F2 condition. Here is a link to the new pump design if you should need it.
Morgan hot tub
if no drain at bottom usually with hose connection on it use a sump pump or syphon make sure power is off until fully refilled
Jun 30, 2014 | Pool & Spa
Washing machine not draining after first wash cycle
Greetings,
If you can open the washer, check the drain pipe cause there is something blocking the water.
The washer's drain function is still working as you can hear it trying.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 21, 2008 | Fisher and Paykel Washing Machines
The washer will not drain I cleaned the bottom drain out and it was full of something that felt like kitty litter (it was not kitty litter) something fell apart when I was washing. I attempted to run a...
Your drain system is clogged with debris. Remove the filter from the bottom left door and look straight back inside the drain system, you will see more debris inside. Do not use a sharp object to remove the debris or you will puncture the rubber bellows. From the back of the machine, remove the back cover. At the bottom of the tub you will find a rubber drain hose that leads from the bottom the tank to the drain filter. Using your hand, gently squeeze the rubber drain hose to "massage" the leftover debris inside. This should help clean out the debris. WARNING: This will cause a major rush of water to come out so be prepared. Good luck
Jun 18, 2011 | LG WM2016C
I have an kenmore elite with error code f02???
The drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap).
Unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Feb 20, 2010 | Washing Machines
We have a GE front load washer WCVH6800. Recently we loaded some throw rugs into the washer. These rugs released a large amount of material. We cleaned the pump filter 3 times and it now seems clean. ...
The water inside the tub will drain out when the pump filter is removed from the pump housing and flood the base of the washer. If not, the tub drain hose is clogged preventing the water to drain into the pump housing then out.
The door is locked because the foam switch in the pressure switch is open due to the presence of water after the unsuccessful drain cycle.
Disconnect the washer from the power outlet. Remove the three screws holding the lower front access panel to the cabinet and pull the panel down to access the pump housing.
Squeeze the clamp that hold the tub drain hose to the pump housing and slide it back. Prepare a pan to catch the water to prevent flooding. The tub drain hose maybe difficult to remove and you may need to insert something under it to break the seal and pull it off.
Remove the tub drain hose from the tub by squeezing the securing clamp and pulling it off the tub drain outlet. Clear the hose and the tub drain outlet from any debris.
Reinstall the tub drain hose and manually unlock the door before reinstalling the access panel. Reach and pull the release ring behind and up the right side of the front panel, then open the door.
Feb 14, 2010 | Dryers
I wonder why there is still water left inside my front load after draining. It used to be totally drained. But now as you turn the drum by hand you can hear water inside of it. My samsung is Wd 6102
Hi the likely problem is a blocked drain filter or a bad pump. Their will either be a small door at the front right or a removable panel under the door. gain access to the pump and beside the pump there will be what looks like a gas cap on a car. unscrew it and clean the filter. If you don't see too much that would block the filter then your problem is the pump replace it. If you have any other questions please feel free to comment. Mike
Dec 06, 2009 | Samsung Washing Machines
At the end of the cycle the water is not draining out of the tub. I vac'ed out the water, removed the filters and checked for debris but found non.
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump (not switching from recirculate to drain) , a wiring problem, or a faulty timer board can be cause the machine not draining.
May 06, 2009 | Bosch SHV46C03 Built-in Dishwasher
Whirlpool Front Loader will not drain or spin
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel (three screws along the bottom). There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
If you need further assistance, let me know
Regards,
reg501
Jul 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Slow or no drain from Kenmore HE3t washer
yes its possable take the hose off of the bottom of the tub and feel up in there to see if you can find it and check the hose its self lots of times you can squeeze it and tell .If its under the tub that would explain it working sometimes and not others.as it would depend on the position of the obstruction when the unit goes into drain i can be more specific if i have the answer to my questions
Mar 15, 2008 | Washing Machines
AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
Mar 25, 2007 | AEG Lavamat 72640 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
199 people viewed this question
Dan Webster
Dan Webster
Sal De
