Question about Hoover UH70015 Bagless Upright Cyclonic Vacuum
The unit works well for 3~4 minutes and then stops. Wait another 10 minutes to cool down and it works again but the same issue happens again and again. It is a brand new unit. I read the manual for the thermal detector and did what it says but the issue is not resolved. Thoughts?
  • 312 Answers
Hi, I have a Hoover Bagless myself. I also have worked professionally fixing Vacuum Cleaners. There may be some material caught between the roller end and the end bearing or the edge of the roller compartment. This could be causing excessive friction causing the motor to overheat. Like a piece of carpet fabric that wrapped around the end. However, that is not supposed to happen to a vacuum cleaner. If you turn the vacuum cleaner over, exposing the brush, you may find it. And be able to remove.
HOWEVER: This is supposed to be a premium Vacuum. It has a very high rating. It certainly is still covered under warranty. I would take my receipt, be safe, and exchange it.
I hope this helps,
Have a Happy New Year
Best, Mark
Posted on Jan 01, 2011
Periodically my Dyson DC07 stops operating, and then will resume operating after about a 10 minute wait period. Is there a thermal switch or "cutout" if the motor is overheating?
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC07 is equipped with a thermostat which shuts the machine down for protection if it starts to overheat. This will often be due to a blockage, and the pre-filter may also be overdue for a wash.
The machine will reset automatically after it's been allowed to cool down, but to prevent this from happening again there are a few simple check you can try: http://www.dyson.co.uk/support/dc07/dc07-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/wand-suction
We recommend washing the filter at least once every 3-6 months, using cold water without detergent. Allow the filter to dry completely before replacing it - this may take at least 12 hours.
Removing any blockages and washing the filter thoroughly should resolve the issue. However, if your machine continues to shut off after you've tried both of these steps please get in touch with us directly so we can talk you through some additional troubleshooting checks. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 10, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Polaris p93 shuts off after a few minutes
Best bet would be return as defective and get a new one
May 27, 2014 | Polaris New P93 Premium Robotic Automatic...
Subject: Eureka Tru Hepa Wirlwind Amps Model 4383. Working fine then just stopped. Later worked fine again? What is/was the problem? Does it need a new filter?? also has the # 0108017529 on machine
I'm not sure all machines are the same, but many have thermal overloads on the motor that can only be reset upon cooling, so wait 30 minutes and try again.
Secondly, my vac has 3 filters, one in the dust tray that you empty, one under where that dust collector installs and the HEPA filter on the back.
Ensure that all three are cleaned.
Gary
Feb 12, 2011 | Eureka 7619AT Vacuum
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
No pwer
Our Hoover U5780-900 stopped working while using the attachment. We let it cool down for about 5 minutes and it fired back up. It appears to shut down when it overheats.
Nov 14, 2008 | Hoover U5780-900 Windtunnel Cyclonic...
Dyson
the automatic cut out switch on the motor needs replacing when the motor gets hot this switch comes in and stops the motor from overheating when the motor cools down the cleaner will work again and cut out again when the motor gets hot if it is not replaced it will eventually burn the motor out after the switch has been replaced both the filter and cyclone need to be cleaned on a regular basis or the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover UH70015 Bagless Upright Cyclonic Vacuum Logo
164 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
