We have a spit system air conditioner.Celestial KFR-70GW/K it is leaking water/condensation internally behind the fan.I think it it from therear grill and for some reason it does not go into the drain tray to discharge correctly. If you have any advice that would be good. I think i need to remove the fan to do any work required.If you can advise how to remove the fan also. Thanks Steve
  • 2,133 Answers
Leaking water from indoor is a common problem. Please check the following:
1. Cooling coil and air filter blocked-Clean it. 2. Drain pan and hos dust blocked-Clean it. 3. Non insulated pipelines-Insulate properly. 4.Less rpm of blower motor.-Replace capacitor.
Helpful?
Posted on Jan 01, 2011
Water is spitting from vents and leaking. i drained the unit but it continues to spit drastically.
These units condense moisture,dehumidifying the air which is good!
They move a lot of air as well, and generally are unfiltered and even filtered
the litle channels for the water to escape to the rear of the unit(outside)
will clog up in their drainpans, the channels are shallow and the drain pain
must be level or biased a tad to the outdoors. The units condensate is to be
routed to the rear where the fan blade has a splash ring on it that splashs the
water on the outside coil. These really need to be removed every other summer at min
and chemically cleaned with condenser coil cleaner that strips the coil clean with a mild acid
to work well
Sep 09, 2011 | Haier hwr10xc6 Air Conditioner
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
I dont have my celestial KFR-28GW\A remote control
Hi, the best way to tell without the manual, would to be to pick up a anolog thermometer, and insert it into the face of the a/c. This will tell you which setting will give you cooler air temperature. They are very inexpensive, and you can get them at most any hardware store or appliance parts store. This will be useful in your auto a/c, refrigerator and so forth. Best of Luck, and Happy Holidays,
Shastalaker7
Dec 17, 2009 | Heating & Cooling
Require instructions and wiring diagrams for Celestial KFR-70GW/K
If you pull the unit out of the case it should have a wireing diagram in a envelope near the compressor
Jul 17, 2009 | Frigidaire FAA065M7A Air Conditioner
Amani Whisper Series Model KFR 70GW keeps turning itself off
Just had the Amani service guy out. Had the same problem. It was the capacitor. Took about 15 mins to fix. The machine turns off to protect itself because it knows something's wrong
Jan 05, 2009 | Heating & Cooling
Celestial split system air conditioner
I am a repair man and have had this problem quite a few times, check that the remote is set to heat and 30 degrees.usually a symbol like the sun,very similar to cool easy to mix up.If the a/c is set to heat the indoor fan will not start till outdoor unit has heated coil.
Jul 16, 2008 | Heating & Cooling
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
