Question about Dryers
Tumble dryer keeps cutting off and switching off all power to sockets
  • Anonymous Feb 20, 2009
    Tumble dryer drum will only rotate half a turn then it totally cuts out. How can I fix it please? All filters etc are clean of lint and fluff etc
    Sergeant:
  • 287 Answers
If your dryer is tripping the main breaker in your swich box, then it probably has some sort of fault, however It could be overheating due to the lint filter being clogged or perhaps if you have it ducted to outside, the duct is blocked.
If these things are not the cause then you probably need a repairman
Posted on Jul 08, 2008
My dryer is only 3 years old and keeps turning its self off. Do I need to get a repair person in or is it something I can do?
You can start by checking on the power from the mains plug. check if there is loose connection on the socket or if this heats up while working to switch off.
Secondly if you can trace the power to the switching panel- control circuit, check for loose joints, connectors. Also check manually the free movement of the motor and drive, if this is jammed it can switch off .
Finally cross check the motor and drive. You can do this with some tips from the link below:
check this out:
http://www.espares.co.uk/advice/tumble-dryers/a/9
Sep 23, 2011 | Dryers
My Hoover tumble dryer plug keeps over heating
The plug is not making proper contact with the socket, causing arcing and heat due to increased resistance. You probably need to change the wall socket, unless you can close the contacts where the plug pushes in. (AFTER YOU HAVE SWITCHED OFF THE MAINS)
Feb 17, 2011 | Hoover Washing Machines
My tumble dryer has just stopped working. have changed the fuse with no joy what could be the problem and how do i fix it
take the tumble dryer out of the socket and then remove the tumble dryer from the socket again and then reattach the socket and the tumble dryer a third time
Oct 10, 2010 | Microwave Ovens
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Tumble dyer
first, you should check the exhaust system, make sure every inch of it is clean on the inside. if it is clogged, there is sensors that turn off your heating element as a safety measure. if this is clean, there is 2 heat sensors, one of them probably needs replaced.
Oct 28, 2008 | Dryers
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryers Logo
371 people viewed this question
Top Dryers Experts
