Question about Amazon Kindle 3G
Kindle will not charge from out let or computer
  • 457 Answers
Please clarify: what charger did you use to connect to an outlet? The Kindle 3 comes with an USB cable to charge from a PC or Mac computer and no charger outside for many countries outside the US (for other countries an external charger is available from Amazon as optional accessory). Use of a different charger (e.g. mobile phone charger with USB connector) is not supported, not recommended and may fry your Kindle if a wrong voltage is hooked to it.
Things you can try:
  1. Use a different outlet to charge the Kindle.
  2. If you use the supplied USB cable to connect to a PC, make sure its firmly seated on both ends. Connect to a powered USB port directly on your computer. Some external USB hubs do not come with a separate power supply (external power supply is mandatory for an USB 2.0 hub, some cheap models are sold without one anyway) and are not suited to charge anything. Just to make sure, disconnect any other USB device except mouse / keyboard to check if the USB port in use is not burdened by too much drain.
  3. The Kindle power LED should glow amber while charging and green if the device is fully charged.
  4. Give the Kindle a reset pressing Home --> Menu --> Settings --> Menu and select "Restart." If the charge light is on but the device is still not charging, contact Amazon customer service.
  5. If the charge light does not light, the AC adapter or cable needs to be replaced.
  6. Contact Amazon customer support for any warranty issues.
Posted on Jan 01, 2011
How can I connect to computer to charge?
You can just plug in the USB cable to the Kindle and then to the computer. Keep in mind the computer must be on in order for the Kindle to charge.
Mar 31, 2016 | Amazon Kindle
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD
I have connected the USB cable to the computer and the kindle and a battery picture is showing as almost empty and it does not seem to be indicating that it is charging.
Try charging it with another charger with the same USB Plug, such as your Kindle charger. Charging from a computer can take a long time, due to the limited power available from the USB port. This will be the definitive test to ensure the Kindle will charge.
Apr 22, 2015 | Amazon Kindle Paperwhite
Why wont my kindle hd charge?
It could be the charger itself. Try taking the USB cable out of the charger and plug it into your computer, then plug in the Kindle. Your computer's USB port should be able to charge it. If it still doesn't charge, you might have a bigger issue with the tablet itself.
Jul 23, 2014 | Amazon Kindle Fire HD
What do ido to make my kindleD00901 operational SCRREN showing critical battery
The nice thing is, that the Kindle/Amazon charger (Ac adapter) is clearly marked as being an Amazon/Kindle charger.
So, here's what you do, perform the hard reset of the Kindle (slide and hold the power switch over to 20+seconds; count slowly; release, then connect to your Amazon/Kindle AC adapter. Then leave it connected for 30+minutes; and should the battery charge, the Kindle screen will return to normal.
Alternate step to try is; if you don't have the actual Kindle AC adapter, you will need to try to charge via the USB port from your computer.
The trick here is, that the Kindle takes longer to charge direct from a computer USB port, and the computer has to be left on the whole time and CANNOT go to sleep, as the power to the USB ports might be turned off.
Also, it's best if you connect to a "powered" USB hub, or the USB ports found at the back of a computer tower (not the front USB ports as most of the time, the front ports do not supply enough power for Kindle charging).
May 25, 2014 | Amazon Kindle 3G
My kindle fire will not turn on
Maybe try taking it where you got it or take it to a computer store. Maybe it could be dead. Try charging it.
May 12, 2014 | Amazon Kindle Fire HD
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
After charging my lindle on my laptop i cant switch it on
Try charging it with the electrical wall plug-in.
I read in some Kindle reviews on Amazon that charging through USB ports on a computer doesn't always work.
Did you get a green light that indicated the battery was fully charged?
Dec 26, 2011 | Amazon Kindle 1
How do i charge my kindle comes on screen battery flat
You kindle should have come with a usb cable (one end is different from the normal usb on things like pen drives) and also a little plug with a usb port on it. If you plug these two together, then plug the other end of the cable into the kindle, once you plug the actual plug into the wall, your kindle should start to charge (you can see this by a light appearing on the bottom of the device). You can also plug this cable straight from your kindle to the computer. This will also charge it (though slower than through the mains).
Sep 11, 2011 | Amazon Kindle 1
I have a kindle and connect to usb on a Windows 7 pc. In the past when I wanted to charge the kindle connected to a Windows XP computer I just clicked on the safely remove hardware icon on my task bar and...
I guess you're trying to eject the Kindle from the task bar "(safely remove hardware". Try going into Start/Computer/right click on Kindle/ select eject. This worked for me when I had the same problem.
Feb 22, 2011 | Amazon Kindle Wireless Reading Device
Amazon Kindle 3G Logo
731 people viewed this question
Top Amazon Tablets & eReaders Experts
castletech
castletech
Martin Murray
Jax Planet
Jax Planet
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
