Locate fuel cutoff switch ford contour gl 1996
  • 312 Answers
If you are referring to the cut off that engages in an accident and has a reset button on it.
That should be located on the Driver's side wall of the Trunk. It may be behind a cover or you will need to remove the side covering (gray colored cloth). I hope this helps,
Have a Happy New Year,
Mark
Posted on Jan 01, 2011
Can you tell me why I dont have no power to the fuel pump on a 1995 ford contour 2.5L duratec? New fuel pump replaced and new fuel pump relay
Have you checked the fuel cutoff switch?
Print
GENERAL INFORMATION
This switch shuts off the fuel pump in the event of a collision. Once the switch has been tripped, it must be reset manually in order to start the engine.
The inertia switch is located on the driver's side of the vehicle behind the kick panel near the driver's feet.
RESETTING THE SWITCH
See Figure 1
Fig. Fig. 1: The inertia switch reset button is located on the top of the switch
  1. Turn the ignition switch OFF .
  2. Ensure that there is no fuel leaking in the engine compartment, along any of the lines or at the tank. There should be no odor of fuel as well.
  3. If no leakage and/or odor is apparent, reset the switch by pushing the reset button on the top of the switch.
  4. Cycle the ignition switch from the ON to OFF positions several times, allowing five seconds at each position, to build fuel pressure within the system.
  5. Again, check the fuel system for leaks. There should be no odor of fuel as well.
  6. If there is no leakage and/or odor of fuel, it is safe to operate the vehicle. However, it is recommended that the entire system be checked by a professional, especially if the vehicle was in an accident severe enough to trip the inertia switch.
REMOVAL & INSTALLATION
  1. Disconnect the negative battery cable.
  2. Remove the driver's side kick panel.
  3. Unplug the connector on the inertia switch.
  4. Remove the retaining bolts and remove the switch.
To install:
  1. Installation is the reverse of removal.
May 20, 2012 | 1995 Ford Contour
My d-in-law had to slam on the brakes to avoid hitting another car, her 1998 ford contour died and now it wont start, could use any info on this. Thanks
The fuel shut off switch may have been activated. It is an inertia switch that shuts off fuel in an accident. It's location would be in the owners manual. Normally is is on the passenger side near the glove box. Feel if it is pushed in all of the way. If it is, than the problem would be something else like a loose battery that shifted and sparked on a piece of metal, blowing a fuse.
Dec 12, 2011 | 1998 Ford Contour
I need to locate the fuel pump shutoff switch in a 1996 contour.
Hello sdn1
The fuel pump inertia shutoff switch, is located under the left side dash behind the left kick panel.
I hope this helpful.
Jul 19, 2011 | Ford Contour Cars & Trucks
Fuel pump has been replaced 3 times and is not working again. What else in the fuel system can be causing the fuel pump failure.
Burned contacts in the fuel pump cutoff switch can cause this as well as a burnt connector to the cutoff switch, the relay for fuel pump can also cause this problem.
Dec 28, 2010 | 1999 Ford Contour
1996 Ford Contour GL 2.0 DOHC Cool fan not coming on.
Did you check the 60A fuse in the engine compartment fuse box?
Jan 19, 2010 | 1996 Ford Contour
96' probe gt car won't start trying to locate fuel cutoff switch and fuel pump
I don't know where or if there is a cut off switch on the Probe but the fuel pump is inside the gas tank.
May 15, 2009 | 1996 Ford Probe
Fuel injector cut off switch for 1999 ford contour se
Try looking by your left foot, while sitting in the drivers seat.
Mar 14, 2009 | 1999 Ford Contour
1996 Ford Contour GL 2.0 liter 4cyl. engine bi/fuel brake booster line broken.
THe main vacuum line should attach to the top of the valve cover sporting a vacuum port about size of a pinky... If it's the main one it is about that size. It runs from brake booster to valve cover
Jun 17, 2008 | 1996 Ford Contour
99 people viewed this question
 Grubhead
Grubhead
