Question about Brother Sewing Machines
F01 code, long beeping and button on lower left fron near needle is red. Won't sew.
    Genius:
  • 1,788 Answers
What model number?
Posted on Jan 01, 2011
I changed the needle on my new Brother HE 240 sewing machine and now the automatic threader won't work. Any ideas?
make sure the needle is inserted all the way into the needle holder
also make sure the needle is turned the right way in the needle
holder
Oct 31, 2012 | Brother Sewing Machines
I get a E4 code whan I turn on machine and I can't figure out what is wrong.
Brother Computer Codes E1: Make sure the presser foot is lowered before sewing.
E2: You chose a stitch other than a buttonhole stitch or a bar tack stitch and you tried to sew with the buttonhole lever in the lowered position. Raise the buttonhole lever.
E3: If you selected the buttonhole or tack bar stitch and start to sew with the buttonhole lever raised, you will get the E3 code. Lower the buttonhole lever.
E4: You hit the reverse button while the bobbin winder shaft was moved over to the right. Move the bobbin winder shaft to the left.
E5: On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
E6: This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
Sep 21, 2012 | Sewing Machines
Cannot get the auto buttonhole to work..it beeps and I can't find the problem
there is a button hole lever to the left of the needle & you pull it
down gently against the button hole foot & the beeping should
go away
Aug 25, 2012 | Singer Confidence 7469 Mechanical Sewing...
My Machine Won't Continuously Sew.
I looked through an online copy of your instruction manual and I don't see a guide which says what that symbol means. To me it means that the upper thread isn't threaded properly. Try one more time to rethread the upper thread but make sure your pressure foot is in the UP position. You may also want to use a piece of unwaxed dental floss and see if you can clean between the tension discs.
I went to Singer for you and found this bit of "help" Perhaps this will help you get back to sewing. It's worth a try.
You may have accidentally lowered the buttonhole lever located just to the left of the needle bar. To make sure it is in the correct position for sewing, place your finger under the lever and push up.
Also make sure the needle is set at the highest position and the bobbin winding spindle has been pushed back to the left or the machine will keep beeping every time you try to sew.
NOTE: To set the needle at the highest position, turn the hand wheel TOWARDS you, until the needle moves to the highest position. Finally, push the reverse button a couple of times, this will reset the machine.
If none of the troubleshooting techniques above solved the issue, please contact a SINGER Service Center to have your machine serviced."
Good luck
Jul 21, 2012 | Singer Sewing Machines
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
After interference, the needle won't reposition left or right properly.
sounds like something got damaged or broke & the machine needs to be checked
Mar 24, 2012 | Brother CS6000i Computerized Sewing...
Singer 7442 sewing machine buttonhole feature beeps and will not work
Make sure to lower the buttonhole lever (fig 3). Its going to be on the left side of the needle.
Let me know if you have any more questions,
Chris
Jun 12, 2010 | Singer 7442 Mechanical Sewing Machine
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
139 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
