Question about Kenwood 1080VR Receiver
Yes My kenwood reciever 1080vr, i set it up i turn on the music the reciver wont let me go past 45 to go louder, then the standby redlight indcator light shows up, what do i do to fix that
Use a rca video cord one end to the video out from the kenwood other end to your tv. with your remote push setup and ajust the db levels. the higher the db levels the quicker protection will shut you down
mr. pepsi
Posted on Nov 19, 2012
Kenwood vr606 reciever shutting off subwoofer and centre speaker simultaneously after few minutes/seconds of powering on. WHat's the cause?
The receiver's out put sections are grouped in pairs. Front left and right in one output, rear left and right in second output, and center channel and sub output on the third. Sounds like a semiconductor or semiconductors have gone bad in the center & sub output.
Nov 19, 2015 | Kenwood VR-606 Receiver
Wont turn on
tuner setting might be default only in stereo only. do you have passive or active speakers?
Apr 10, 2014 | Harman Kardon AVR 240 Receiver
Kenwood SW-32HT Subwoofer Dropping sound Yamaha Reciever
Several possible answers. First - is that the Yamaha has a fault that is sending a signal with too much power on it. And the sub detects this and switches off.
Second - either the Receiver or Sub is switching off when no audio is present. A setting problem?
Third - the sub has a fault, possible overload, and goes to standby for safety.
Jul 01, 2017 | Audio Players & Recorders
I have an onkyo reciver and 7.1 speaker system. The powered sub-woofer keeps timing out and when I run the automatic speaker test on the reciever, it does not see the sub-woofer. I checked the reciver...
I assume you mean the subwoofer remains silent during the test. Perhaps the subwoofer is where we should be looking.
If you jack it into one or both of the Tape Out connectors and play some music with substantial low bass, does it make any sound? This would at least prove it is alive.
Dec 13, 2010 | Onkyo TX-SR605 Receiver
Kenwood Receiver VR 806 turning off
Sounds like the music amplifier is different to the tuner audio amp. The music amplifier is now looking at an unbalanced impedance which is less than it should be. Therefore the output chip of the music amp has more current through it than it wants so it gets hot and shuts down.Put a four ohm wirewound resistor ( from Radio Shack ) in series with each surround speaker to reduce the current flow through the amplifier output.
Apr 09, 2010 | Kenwood VR-806 Receiver
SOUND CUTS OUT WHEN VOLUME IS PAST 15
thats to stop you blowing your speakers. you can make your volume louder via the equaliser/surround settings, but you will still not be aloud past the number 15 without it cutting out.
its an EU setting thats on most mp3 players too, so that people wont listen to music too loud, "nanny state".
hope this helps
kev
Oct 02, 2008 | JVC Audio Players & Recorders
Speaker set up and adjustment
CHECK THE FRONT OF YOUR AMP FOR A SET UP BUTTON OR MENU BUTTON,THIS SHOULD LET YOU SET UP YOUR SUB AGAIN.
HOPE THIS HELPS
CABLE GUY.
Jun 18, 2008 | Kenwood 1080VR Receiver
Kenwood Home Theater
Please update your post with any Model Numbers that you can retrieve, especially the subwoofer. Off hand, and with the limited amount of information that you have provided, I would GUESS that your subwoofer is simply overheating, and is being shutdown internally, hence protecting the fuse because no short is detected. If you haven't moved and or vaccuumed/cleaned around or near your system regularly, dust, pollution, pollen...you name it, builds up and can easily prevent electronics from breeathing/venting properly.
Jul 31, 2007 | Kenwood HTB755DV System
Kenwood 1080VR - shuts down
try unpluging it all plug in sumware else see if it just turns on
Nov 16, 2006 | Kenwood 1080VR Receiver
Kenwood 1080VR Receiver Logo
79 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
