Question about Kidz Toyz Kidz Kawasaki Walkie Talkie Kdz22210
We got these walkie talkies and the range is limited to about 3 feet, do I need to do some thing with the code key button, or a way to modify the frequency?
I have slyvania walkie talkies model no.fbs201 working but not sure how to turn off and on..
I could not find your model on the internet. Sylvania was never a walkie talkie manufacturer, so they were made by someone else. The ones I found on eBay had an off/on switch tied to the up down keys. Try pressing and HOLD for about 3 seconds the left side bottom button, then release. If that did not power it on, try the other buttons but be certain to HOLD for about 3 seconds since the button is dual purpose.
Oct 31, 2016 | Walkie Talkies Radio Communications
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
What does Mon mean on a walkie talkie?
"Mon" is short for "Monitor" and is usually a feature that allows you to momentarily break the squelch (signal filter) and hear anything being transmitted on that frequency. That includes static if there's no transmissions. It allows you to listen for a weak signal that can't break the squelch threshold you have set. Some radios allow you to lock it open by pressing and holding the MON button for a few seconds. Turn the feature off my doing the same thing.
Jul 03, 2014 | Motorola Walkie Talkies 23-mile Range...
What is the range of the uniden black walkie talkie gmrs 520
  • Pair of GMRS/FRS 2-way radios for person-to-person communication while hiking, skiing, and more
  • 22 channels (8 GMRS and 14 FRS); wireless range of up to 2 miles
  • Auto squelch function shuts off weak transmissions and unwanted noise at range limit
  • Single call alert tone; automatic power save circuit extends battery life; includes 2 belt clips
  • Each radio runs for up to 48 hours on 3 AAA batteries (not included); 1-year warranty
May 30, 2014 | Uniden Black Walkie Talkie Gmrs 520
My Uniden walkie talkie keeps saying L very time I push a button
You've set the keylock feature on your walkie talkie. From the Uniden manual...
KEYLOCK
ON/OFF Press and hold the call/lock key until the "L" appears. After 1 second, the LCD will return to the channel display. To exit Keylock on mode, press and hold call/lock again. Note: While in keylock on mode, it will still receive transmissions.
Feb 10, 2014 | Uniden GMR-1035-2 2-Way Radio
Uniden walkie talkie says L every time I push a button
KEYLOCK
Feb 10, 2014 | Uniden Radio Communications
Manual
where do I find the user manual for my spy gear long range walkie talkies model number 70437.
May 10, 2013 | Wild Planet Spy Gear Long Range Walkie...
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press
MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either
+ or to turn On or Off.
3. Press the PTT to confirm or
MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
Oct 23, 2008 | Motorola FV200AA GMRS/FRS 2-Way Radio...
Kidz Toyz Kidz Kawasaki Walkie Talkie Kdz22210 Logo
41 people viewed this question
Top Kidz Toyz Toys Experts
ray gallant
Are you a Kidz Toyz Toy Expert? Answer questions, earn points and help others
