Question about HP LaserJet 3050 All-In-One Printer
HP 3050 door open message - HP LaserJet 3050 All-In-One Printer
  • 45 Answers
Your printer HP 3050 has problem of door open the printer had 3 or 5 senser in which one senser is not working so the message comes on screen
Posted on Jan 01, 2011
2 Suggested Answers
doniteloon
  • 144 Answers
SOURCE: My HP 3050 deskjet printer says there is door
hi there!
please check on the top cover, front side cover or if the printer has duplexer (at the back) check that too, open them up and close again, make sure you hear the snap sound. here is the link for that printer too, look for manual guide, you can get it here for free or if you're in the USA, contact 800-HP invent for technical support:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=1140778&taskId=135&lang=en&cc=us&prodSeriesId=1140783&prodTypeId=18972
Posted on Apr 07, 2011
PERMANENT STORAGE INIT IN PRINTER HP 3050
If you have another same model printer, replace this formatter to another working printer check, no message? wait 10 minutes remove and install it back and check..If found same message replace formatter..
Jan 30, 2012 | HP LaserJet 3050 All-In-One Printer
My HP 3050 deskjet printer says there is door open, but i can't find it. Can you help please?
hi there!
Apr 07, 2011 | HP LaserJet 3050 All-In-One Printer
HP 3050 paper feed jamming problem
HP paper feed error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 04, 2010 | HP LaserJet 3050 All-In-One Printer
OPEN DOOR
Try doing an nv ram
1. Turn the printer off
2. Hold down the select and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
if this does not work it could be an actual sensor that is damaged.
Al
Eliteprintersolutions@gmail.com
Jul 09, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 scanning error message
Good day!Try to check the feeder if it has paper on it..then try on and off the printer until it holds normal status..
mastergani
Mar 29, 2010 | HP LaserJet 3050 All-In-One Printer
HP Laserjet 3
If the adf is not working on the 3050 check the firmware, print out a configuration report and verify the firmware datecode, it is under the product info portion of the report. You can see which is the latest firmware by checking on the hp.com website under support and drivers, after the firmware is updated, check the rollers. open the door up and see if the roller is lifter off of the cork piece of not try resetting the roller.
Al
Feb 25, 2010 | HP LaserJet 3050 All-In-One Printer
Scanner does not work message Waiting for PC
my hp laserjet 3050 prints but i need the driver to scan a document.
Apr 18, 2009 | HP LaserJet 3050 All-In-One Printer
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Dec 14, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
1,160 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
