FixYa.com
Tags:
RCA D52W20 52 in. Rear Projection HDTV-Ready Television
Power
posted by webby_1976 on Jul 08, 2008
i have a 52 inch rca hdtv television. it comes on and goes right back off and i was wondering if there was a reset button or something we could do to save money on getting it fixed. could u help me?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 11, 2008
Not Rated (0)
willtab
Rank:Guru Guru
Rating: 89%, 351 votes
The rca itc222 chasis. I see alot of these sets in the shop. first question... does the front led flash green or come on at all. if so then that elemenates the "main fuse" the processor is recieving power and then it "sees" a problem then shuts the set down. The problem is with these set it can be one of about 25 different problems. Most of them involve the high voltage source. Technicians have a special computer interface much like a automobile to read" error code". that help them determine the problem. The only thing you can try is unplug the set for 30 min then try again to turn it on...
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
RCA D52W20 52 in. Rear Projection HDTV-Ready...
rca converter box
my converter box fell off the... Answer This...
won't turn on
I push the power button and it... Answer This...
d52w20bxy1- 52" RCA Rear...
I've posted and still have not... Answer This...
Lost color
I think a color tube, but I'm... Answer This...
RCA D52W20 Resetting Factory...
I have a RCA D52W20. The... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
