Question about Westinghouse Refrigerators
Rj532 freestyle not draining correctly. Water gatering in fridge compartment and leaking onto floor
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
  • 24 Answers
SOURCE: water leaking out onto floor
Scott you are dead right with the drain. If you open the freezer door and look inside at the back in the middle of the plate at the back on the very bottom there is a small hole. This hole goes all the way down through the fridge and then finally to a dish that sits ontop of the compressor via a hose. If any part of this hose is blocked then it will find an easier path which is uually out the front and on the floor. The most likely culprit would be ice. Leave it off for a half a day or so so the ice melts then turn it back on and test it for a week. Do not turn the thermostat up very high otherwise the problem will reoccur.I hope this helps.
Posted on Oct 08, 2008
  • 108 Answers
SOURCE: Westinghouse Aurora Frost free fridge
You need to remove the clog in the drain line from the freezer to the condenser, Look under the fridge for the plastic drain line and blow it out or otherwise clear it, Then insure that the unit is level. Sooner or later you need to clean the freezer drain pan. After using up your frozen food, remove the back panels of the freezer and clean the area well.
Ray
Posted on Oct 29, 2008
aasc
  • 1606 Answers
SOURCE: Freezer leaks water even after water supply turned off
Remove the food from the lower portion of the freezer and remove the 2 screws which hold the rear freezer panel on . Remove the panel and use a hair dryer to defrost the ice built up over the drain . Once you see the black drain hole , concentrate on defrosting the hole . Once defrosted , the ice water will drain into the hole . I would use a small hose inserted into the drain and blow thru , to remove any debris built up inside the drain . Reinstall the panel and food .
Posted on Aug 09, 2009
woodchuck789
  • 4059 Answers
SOURCE: How do I unclog defrost drain on a model TBX18W?
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 26, 2009
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Where is drainhole in westinghouse freestyle refrigerator
usually located midway of fridge compartment in center its a small one usually covered with a casing or cover sometimes? some are located at center sides or bottom of fridge. if u look under the fridge and see the tubing then follow it up and get an idea where that drain plug is?
Dec 04, 2014 | Westinghouse Refrigerators
Refrigerator leaks onto floor?
when fridge goes into deffrost water from defrosted ice should drain to underneath fridge. drain could be clogged.... or ice has buily up over drain hole.
Sep 01, 2014 | Refrigerators
How to access drain hole for maytag model mf12269vem3
please check your ice maker to make sure it is not jammed up water can leak into fridge
Nov 01, 2013 | Freezers
Frozen water on bottom of whirlpool model evl181nxtq01
I assume that the water is on the bottom of the fridge compartment? It could be that the drain trough has blocked and every time the fridge does an auto defrost, water runs out onto the floor of the fridge rather than down the drain. Once the defrost finishes, the water will stay on the floor of the fridge. Cold air falls to the bottom so its possible to get a sheet of ice in the bottom of the fridge. Locate the drain trough in the back wall of the fridge. See if you can visually locate any blockages or carefully dribble warm water down the drain to clear it.
Oct 19, 2013 | Whirlpool Freezers
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Westinghouse freestyle fridge rj532s-r is leaking water inside fridge compartment
You have an obstructed drain in the freezer or within the drain tube itself. You may have to thaw the unit to fix the problem, but it not terminal and you should not need parts, just need to locate why the water is collecting and clear the tube.
Good Luck
Sep 23, 2011 | Refrigerators
Our Hotpoint Ice Diamond fridge/ freezer has developed a slow leak, or rather, it collects water condensate on its floor in the upper compartment which then oozes out onto the floor. I don't have a...
Thier are 2 possible thing causing that leak.
1 ) a blocked defrost drain..this tip i wrote will tell ya how to clear the defrost drain
FREEZER ON THE TOP OR BOTTOM http://www.fixya.com/support/r9945686-check_when_refrig_cools_ok_but_leaks
SIDE BY SIDE http://www.fixya.com/support/r9991618-wrong_when_side_side_refrig_leaks_from
2) the water inlet valve that distributes water to icemaker and in door dispenser (if equipped) hasa pinhole in it and spraying water onto the floor...to check that gotta pull out ref.from the wall and remove lower rear service plate and inspect the valve for a pinhole
GENE
Aug 31, 2011 | Hotpoint Refrigerators
My westinghouse fridge model RJ532 Freestyle is leaking water on the floor
internal water drain is blocked - get very thin copper wire and unblock -
Jul 30, 2010 | Microwave Ovens
Refrigerators Logo
67 people viewed this question
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
