Canon PIXMA iP90v Printer Logo
Posted on Jan 01, 2011
My computer tells me that my ip90V printer waste ink tank is full and the printer light blinks. I can find no way to remove the waste ink tank to empty it.
5 Related Answers
A
Anonymous
  • Posted on May 01, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Anonymous
  • 88 Answers
  • Posted on Oct 06, 2008
normally, the logical solution is to replace your waste ink tank, but I have tried a solution which could make your canon printer function again.
Try this: With your printer turned ON, press and hold the I/O switch then pull off the power cord. This will turn off your printer. But without lifting your finger on the I/O switch put back your power cord. the I/O switch will blink for a second and will go off, then turn-on your printer again and see if it works.
Anonymous
  • Posted on Apr 09, 2009
SOURCE: ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Anonymous
  • 56 Answers
  • Posted on Sep 14, 2009
SOURCE: tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
pineworks
Clive
  • 4362 Answers
  • Posted on Feb 13, 2010
SOURCE: Waste ink tank removal
ok
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Testimonial: "Very helpful. Would still like to empty the waste ink tank for copy quality purposes. I need an exploded assembly diagram / service manual. Any thou"
What does "the waste ink absorber is almost full.
IT means that the pad in the printer that absorbs excess ink is full. This costs a lot of money to replace, probably more than you paid for the printer. Just resume printing.
It says that the ink absorver is almost full and printer does not print job
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
7helpful
Canon pixma ip90v waste ink absorber is almost full . please help me to resolve this problem
It's not a problem, just a fact of life. The old ink has to go somewhere and when the drain pack is full you need a shop to replace and access the service mode to reset the counter. It involves removing all the top covers, lifting out the print engine and replacing the drainpack.
Waste ink absorber tank full
The old ink has filled the drain pack. It is now full so you need a shop to replace and access the service mode to reset the counter. It involves removing all the top covers, lifting out the print engine and replacing the drain pack.
MY Pixma IP90v has an error message waste tank full. Can I fix that myself or do I have to take to a repair station?
You should send it to service centre
2helpful
2answers
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
1helpful
Tank absorber full and lights blinking
Note
2helpful
Pixma Ip90v waste ink tank full
you need to clean the ink tank...it is usually located at the right most part below the printer cartridges.(cartridge ducking station)
check your user manual on how to disassemble your printer or ask someone to do this for you if you are unfamiliar with printer disaabling.
let us know.
4helpful
You have to send it to your nearest service centre.
old marine
old marine
ZJ Limited
ZJ Limited
