Question about HP OfficeJet J4580 All-In-One Laser Printer
I upgraded to Windows 7 today and cannot get my printer to work!
    President:
  • 1,082 Answers
Can i upgrade from 32 bit to 64 bit on an Acer 5630 laptop?
I would check with the microsoft.com website for this. I believe many computers can be upgraded to the 64 bit version of Windows 7. The limitation, about 1 year ago, was that many drivers were not available on that platform, and many accessories would not work with the 64 bit version of windows 7. However, today, there are many computers coming out with the 64 bit version of windows 7 and that means that probably you could upgrade to 64 bit and most things would work correctly.
Good luck on this upgrade.
Feb 04, 2011 | Acer Aspire 5630 Notebook
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Printer does not recognize Windows 7, just up to visa and I just purchased this printer.
Try running your computer in XP mode until you get the proper upgrade for your printer.
These pages should have everything you need to make the transition if you can't get an upgrade to your printers software. If you go to your printer manufacturers website you should be able to find out whether there is an update available to help your printer work with Windows 7
http://windows.microsoft.com/en-US/windows7/install-and-use-windows-xp-mode-in-windows-7
http://windows.microsoft.com/en-US/windows7/Make-older-programs-run-in-this-version-of-Windows
Hope this helps.
Nov 26, 2010 | Computers & Internet
Upgraded from Vista to Windows 7 32 bit. Now printer won't communicate with my laptop
better check your printer manual that if it work on windows 7 otherwise it wont work, better download a new driver software for your printer from the manufatures website. and you have to specify Windows 7 32 bit. it will work.
Feb 03, 2010 | Lexmark X4550 Multifunction Wireless Color...
Need a driver that works with windows 7
If you have recently upgraded to Windows 7, please view the link at the top of this support page entitled "Upgrading to Windows 7?" for important steps to get your Lexmark X5470 installed properly.
Lexmark X5470 Downloads
Be sure to download the correct files.
Jan 12, 2010 | Lexmark X5470 All-In-One InkJet Printer
I am having problems installing canon iP5200 with Windows 7
Did you upgrade the computer from Windows XP to Windows 7? If so, did you uninstall the driver before you did the upgrade? The old driver files may be causing the problem.
To fix, go to this link, and in the search box in the center of the screen type "windows 7" and click on the Search button. Then select the link "ERROR: Cannot communicate with the printer after upgrading to Windows 7". There will be step-by-step directions for resolving your problem.
Dec 29, 2009 | Canon PIXMA IP5200 InkJet Photo Printer
Hi i am trying to upgrade my window 98 to window 7 but explorer won't let me download it how can i upgrade my computer to window 7
:L You Cant Upgrade From WIndows 98 To Windows 7 Your Pc is too old and The hardware is Gonna be outta date
Nov 16, 2009 | Microsoft Windows 98 for PC
I recently upgraded my home computer to Windows 7. Today I downloaded new drivers for my printer Lexmark X2500 (paid $39.95). My printer does not work. Do I now have to uninstall my printer and...
HI,
First Disconnect the printer and uninstall the Lexmark drivers/softwares,give your pc a restart and then click on the below link and click run to download the windows 7 drivers for your printer.After the download is done,just follow onscreen instructions to install the software.
http://www.downloaddelivery.com/downloads/cpd/cjb2500Win7en.exe
Just follow the instructions i gave you carefully.Your problem will be solved.
Thank You for using fixya.
Nov 13, 2009 | Lexmark X2500 All-In-One Printer
Just upgraded to Windows 7 64 bit I was using
You can still use the printer if it is supported by Windows 7 operating system, but if it is not supported, then by a new printer that will work on Windows 7.
Nov 10, 2009 | G7 Productivity Systems VersaJette M300...
HP OfficeJet J4580 All-In-One Laser Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
