Question about Lutron 600-Watt Multi-location Dimmer Switch by Electronics, Inc
I installed the dimmer 600 w and now the light bulb is flickering like a disco. Is it the bulb that I need to change or an adjustment on the actual dimmer.
    Problem Solver:
  • 5 Answers
The Dimmer & the Lamp MUST MATCH.
If your Dimmer was intended to operate with INCANDESCENT (original Light BULB, not CFL), it will ONLY work correctly with TUNGSTEN or HALOGEN Lamp Bulb.
If your Dimmer was designed for use with C.F.L. it will not operate with original Tungsten BULB type Lamp (AKA "Type A Bulb").
Most likely your trouble is you exchanged the burnt original Tungsten BULB for C.F.L.
The original Tungsten & Halogen type Dimmers always rated for 600 WATT, so I can bet $$$ that it requires Halogen or Tungsten to be a proper match.
You can have both types on the same Circuit at the same time, but never try to mix BOTH Halogen/Tungsten AND C.F.L. or L.E.D type Lamps on old style Tungsten Dimmer Switch.
Remember- Tungsten & Halogen= the same- you may combine *only* these 2 Lamps together on an old fashioned 600W Dimmed Circuit.
Posted on Apr 13, 2014
    Problem Solver:
  • 12 Answers
Are you using one of those florescent bulbs? They generally can't be dimmed.
Posted on Jan 16, 2011
WHEN ON DIM THE LIGHT FLICKERS
That is because the dimmer is designed for incondescent lights and you are using compact fluorescent. To solve the flickering problem add at least one regular bulb to the system. If there is only one bulb then replace with a regular bulb if you are using a dimmer.
Apr 30, 2013 | Lutron Electronics Toggler Preset Dimmer,...
When I dim the light it starts flickering--I have a 3 way TG 600PH-WH
Check rating plate on device, or rating that shows in product manual.
Also if the dimmer does not need neutral wire to power the device, then it will be rated for incandescent-only, and not be rated for CFL
This dimmer is for incandescent light only up to 600 watts, and will not work as expected for CLF bulbs etc
Dimmer flickers
most likely the type of lamps/bulbs you have are not compatible with the dimmers.
Mar 21, 2013 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
Lutron s-600 don't seem to function
That switch says on it that it is for fluorescent lights only. I don't know if you can use compact fluorescent bulbs on that system, perhaps verify if you can or not. The switch has electronics in it and may need that ground wire to get 120 volts to operate. If you have incondescent light bulbs return and get the correct dimmer.
Mar 16, 2013 | Lutron S-600-wh Skylark Incandescent...
Installed 6696 When turned of the lights flicker light bulbs are energy saver not incadescat
This switch is made for incandescent load only up to 300 watts.You will need to find another type of switch or change your light bulbs to incandescent bulbs.
http://sbeelectricandhvac.com/
May 23, 2011 | Leviton Anywhere Switch - 6696-W - White
I have a problem with my kitchen's recessed lighting. For some reason, the six bulbs will go out during the evening hours, then come back on. There is no pattern, with one, two, three or four of them out...
It sounds as if you may have higher wattage bulbs and/or the wrong type of bulb installed in the can fixtures than the recessed cans are rated for.
When the wattage of the bulbs is higher than the rating of the fixture, and/or the wrong bulbs are being used, the recessed can's thermal overload device will shut off the light, to prevent damage and a possible fire situation.
It is unlikely that you've got a faulty dimmer, since you state that not all of the lights go off at once, thus it can be narrowed down to each can and thus the thermal overload being the culprit.
I would suggest you look inside the recessed can light fixture and determine what the maximum wattage bulb you can use, (60, 75, 90 watts, etc.) and use the next lower wattage bulb instead. I also install only Halogen bulbs in recessed cans, (they have a flat lens vs. a rounded bulb lens area like PAR type bulbs). Halogen bulbs are also the most efficient incandesent bulb that provides the whitest light possible and directs more light (and thus heat) downward away from the recessed can.
I avoid using a standard light bulb or PAR type bulbs in any recessed can fixtures as they tend to heat up quite a bit and cause the thermal protection to trip frequently.
As a Master Electrician that has installed literally thousands of recessed fixtures and dimmers, I can say that my customers prefer the Halogen light over standard bulbs and they last longer too.
I hope you find this Very Helpful and best regards!
Sep 17, 2009 | Lutron Diva Dv-600P Light Control By
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Hampton bay CFL lights flicker when they are turned off
I believe the flickering comes from the way the CFLs extinguish themselves after the remote turns them off. As the other poster said, turning them off with the wall switch as well after turning them off with the remote stops the flickering.
It is because the remotes are a dual mesh type of signal, which uses the RF as well as the electrical power to activate and turn them off.
Actually, this type bulb is not designed to work as well in dimmers or remote switches as is incandescent. You will find if you replace them with regular incandescent they will not flicker.
Sirwriter
Apr 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Lights flicker when dimmers are not at full strength
Are the lights the new high efficency flouesent bulbs. If so the will flicker on a dimmer switch. The older dimmer switches are for incodescent bulbs only. Hope this helps. Pls rate the answer.
Kurt
Mar 25, 2009 | Electrical Supplies
Lutron 600-Watt Multi-location Dimmer Switch by  Electronics, Inc Logo
345 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
jdthefixer
berniekruege
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
