Question about LG Heating & Cooling
Hi, I ve got a aircon LSZ244VM4 inverter and fault code is CH 61.Iam out of warranty 1 yr and the unit has already been replaced 1 time when it was in warranty.So what should i do now and what does CH61 mean?
  • 2,133 Answers
Ch-61.Condenser coil over 65°C. Check coil and filters are clean and free from debris, and airflow is OK. Check system pressures for non-condesables
Clean coil & filter. If non condensable gas, remove gas and flush out the system. Vacuum and recharge.
Posted on Jan 01, 2011
Error code ch 61
try cleaning the outdoor unit with a hose pipe. the err code is caused by high pressure on the outdoor unit. please also check if the fan outside runs when the compressor is on, if not the fault is probably caused by the fan or fan capacitor being faulty.hope this is helpful.
Mar 04, 2016 | LG Heating & Cooling
LG air conditioner model number LMN095HVT units keep on flashing with error code CH 46 and with no response at all. How can I fix it? Thanks for your help in advance!
ERROR CH46:
Outdoor unit suction sensor fault. Disconnect from PCB and measure resistance. 10 kOhm at 10°C and 4 kOhm at 30°C. If OK replace PCB, if not replace sensor.
Sep 01, 2015 | LG Heating & Cooling
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
the problem with the electronic ones is they usually need repairing by a service centre or aircon guy and if it's not under warranty they'll be able to recommend their repairer. We had a similar fault where there was just some random code error. It happened during a heat wave and it turned out the fan motor seized and the board got burnt out. They had to replace they board so that may be what you're up for.
Dec 14, 2014 | Fujitsu Heating & Cooling
Self test error
Is the UPS in Bypass? Is the Inverter running? What alarms other than that code are on? Have you shut the unit down. Its best to call MGE, that unit requires to have software to work on it. Even though you find the problem, and replace the board, the Board needs to be program to that unit. YUP! This way MGE always makes money on the UPS's no matter where and no matter how old the UPS is. They lock you out. Which is unfair for the customer. The customer has no choice but to call the dealer to fix it. Trust me.. Then again when a customer buys a product, isn't it his for life? Why can't he fix his ups or hire whoever he wants besides the Manufacture? Wrong, NOT WITH MGE Products. I guess it's Job Security for MGE. That one positive thing.
Jan 23, 2014 | MGE Galaxy 3000 UPS System
We have 2.0 HP inverter wall mounted LG aircon, when we turn on the ac, the indoor unit only is running and shut down after 3 mins. What is the solution?
Hi Marie, does the green indicator light on the front panel flash after it shuts down? If it does...count how many times it flashes this will refer to a fault code diagnostic.
Keith.
Jan 02, 2014 | LG LS-K2430HL Heat Cool Mini Split Air...
Panasonic fault codes
I found this error. The simple possible resolution is to reset the circuit breakers feeding this unit and/or replace possible blown fuses. Other possible problems may be too involved therefore a professional should be hired. Just a warning, this problem could get expensive.
Dec 11, 2013 | Heating & Cooling
The video on our Insignia 32" LED-LCD HDTV, 1080p
Hi Joyce,
First of all thank you for posting your question here at Fixya.
I've suspected that the fault is not the cable reception, hook up, but inside the set. To confirm it, check if the symptoms remain the same no matter what the input is (DVD/BD player, game console, direct TV, etc.). If the problem still persist, then the fault is either the inverter board or the backlight of the TV.
Backlights are the one generating the brightness backround of LCD to see the images generated at the LCD panel. It has a high voltage source that will light it up and that is the inverter board. If one of the backlights fail, it will produce overload to the high voltage transformer of the inverter board and will sensed by the feedback circuitry and will automatically shuts off the power supply of the inverter board to avoid further damaged. Same when the inverter board gone to malfunction, the feecback circuitry will automatically shut off its power supply.
The backlights and the inverter board must be checked to isolate where the fault came from. Most of the faulty backlight has a physical indication of fault like blacked end, and can be easily identify through visual inspection. If the backlights are in good condition, then the fault is the inverter board. Ebay.com and shopjimmy.com is a reliable supplier of parts, check your model no. at the rear panel and then search it to their search engine and all available parts will be displays.
Also, I would advice you to double check if your unit is under warranty period (1 year), if so, avail it because the manufacturer will fix it for free. Opening the rear panel will void the warranty.
Please let me know if you need further assistance.
Hope I gave you an idea what's going wrong to your unit.
Have a nice day!
Good luck and take care!
Kind Regards,
Jdvillanueva
Dec 15, 2011 | Insignia Televison & Video
Nw my lg Aircon appear CH 46 how to solve this problem
Nov 18, 2010 | LG Art Cool LA181CNW Split System Air...
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
ERROR CODE ON AIRCONDITIONER LG ART COOL INVERTER MODEL NUMBER LSZ244VM4
Error C6 on lg cool art is common. you guy need a new CAPACITOR. cost $7.05c aud. it's 6uF 450vac.
take about less than 10min to install.
my lg model is lsz244vm-4, it's run well now.
Jan 02, 2008 | Heating & Cooling
Heating & Cooling Logo
710 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
