Question about Sharp EL-1801C Calculator
I have a sharp EL-1801C and having trouble with basic addition and subtraction. Was wondering if it could be a setting problem? For example: 100+50=100 or the answer always is the first number of the equation. Please help ASAP! Getting very frustrated and need to use it as soon as possible. Thank You, Rita Gosselin
5 Suggested Answers
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
  • 8068 Answers
SOURCE: how do I use sharp EL 531W to solve quadratic equations?
This calculator does not have a program to which you give the equation, and which returns the solutions. Sorry. You have to use the formulas you learned.
Let the equation be ax^2 +bx+c=0
You compute the discriminant Callit disc.
disc= (b^2-4*a*c)
1. If discriminant is larger than zero you have two solutions. Let us call them x1 and x2.
Then x1=(-b+square root of disc)/(2*a)
and x2= (-b-square root of disc)/(2*a)
2. If disc=0 , square root of disc =0 and x1=x2=-b/(2*a)
3. If disc is negative, there are no real solutions.
To find the solutions you replace a, b, and c by their numerical values, to calculate disc, its square root, and calculate X1 and X2.
Hope it helps.
Posted on Sep 17, 2009
  • 8068 Answers
SOURCE: how to solve quadratic equation in SHARP EL-531WH
You compute the discriminant Call it disc.
disc= (b^2-4*a*c)
Hope it helps.
jyackle5
  • 8197 Answers
SOURCE: how to replace ink roll for sharp calculator
Here is the manual on link below on page 5 tells you how to replace.
http://dl.owneriq.net/e/ea19126b-3714-4b3d-bce5-712458b60c6d.pdf
Good luck and please rate 4 thumbs for the free answer
Posted on Mar 14, 2010
How do I set the decimal to automatically enter for dollars and cents on my Sharp EL-1197PIII?
Set the Mode selector to "A"
Set the Decimal selector to "2"
In addition & subtraction you will automatically get 2 decimal places without entering the "." just enter 1250 and it will print 12.50
In multiplication/division, you must enter the "." (decimal point).
ie: 12.50 x 2 = 25.00
Sep 08, 2017 | Sharp Office Equipment & Supplies
How can I get my sharp calculator to add and subtract correctly?
Could it be that it has adding machine logic and not calculator logic?
Let's do an experiment. 3+ 3+ 5-. Is the answer 1?
If so, it is working like an adding machine. Every number you enter is considered positive or negative and it keeps a running total.
Let me know if you have any questions.
Good luck.
Paul
Feb 25, 2015 | Sharp "el-2630piii desktop calculator,...
How do you do hexadecimal addition on she Sharp EL-W535HT?
Press [2nd F] [x: multiply sign] to enter Hexadecimal base calculation. The digits are 0,1, ...9, A, B, C,D,E, and F.
Enter a number in Hex, press the + sign to perform and addition or - for a subtraction. Press the = sign to obtain the result.
Feb 19, 2012 | Sharp Office Equipment & Supplies
How to change the tax rate on a Sharp EL-1801C calculator
Enter the desired number for the tax rate... followed by hitting the "STR" button... followed by hitting the "Tax+" button. Here is a link to the manual for the Sharp EL-1801C. http://bit.ly/lf3edL
Jun 19, 2011 | Office Equipment & Supplies
How do I print the total amount on my ticker tape of what I've added? I pressed the equals sign but that didn't work.
OFF • P P•IC
ON POWER SWITCH; PRINT / ITEM COUNT MODE SELECTOR:
"OFF": Power OFF
"•": Power ON. Set to the non print mode.
"P": Power ON. Set to the print mode.
"P•IC": Power ON. Set to the print and item count mode.
1) For addition or subtraction, each time is pressed, 1 is added to the item
counter, and each time is pressed, 1 is subtracted.
• The count is printed when the calculated result is obtained.
• Pressing of , clears the counter.
2) When the grand total/rate setting mode selector is in the ON position (GT), the
counter will count the number of times that the calculation results have been
stored in the grand total memory. To print and clear the count, press the key.
3) The memory item counter will count the number of times that the key has
been pressed in the addition.
Note: • Each time the key is used in the subtraction, 1 will be subtracted from
the count.
• The count is printed when the memory is recalled.
• Pressing of the key clears the counter.
Note: The counter has a maximum capacity of 3 digits (up to ±999). If the count exceeds
the maximum, the counter will recount from zero.
Dec 17, 2010 | Sharp EL-1801P Calculator
I cant find where the ink cartridge is on the sharp EL-180P
Not familiar with your model but others I have serviced used an ink-impregnated roller rather than a ribbon; you may be looking for the wrong object. They were generally rolling directly on numeral roller.
Apr 15, 2010 | Sharp EL-1801C Calculator
How to replace ink roll for sharp calculator EL-1801c
Mar 12, 2010 | Sharp EL-1801C Calculator
SETTINGS
Check the Decimal / Add Selector. It shoul be set to "A" (Add mode), to permit addition and subtraction of numbers without entry of the decimal point.
You may also want to download the SHARP
EL-1801P Operation Manual
Jun 22, 2009 | Sharp EL-1801P Calculator
Sharp el1801c ribbon
Lift the clear plastic thing between the calculator and the ribbon.
Thanks, Logan
Jan 16, 2009 | Sharp EL-1801C Calculator
Manual
How do I subtract on Sharp EL-180 1V calculator?
Jul 25, 2008 | Sharp EL-1801AII Calculator
Sharp EL-1801C Calculator Logo
47 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
