Question about Homelite ZR10926 16" Chain Saw
When running for bout 10 mins the muffler gets glowing red
    Sergeant:
    Champion:
  • 226 Answers
Replace the muffler it is burn out. I hope i help you out let me know.
Posted on Jan 01, 2011
  • 2,428 Answers
For some reason its running way to lean richen up the fuel mixture or rebuild the carburator its going to melt
Why is my rztl over heat ?
weak mixture cause that, possibly with retarded ignition timing as well.
Aug 07, 2017 | Cars & Trucks
Why does my 14 1/2 hp briggs and stratton riding mower muffler glow red after 2 min running..runs ok..just glowing red muffler.
Possible bad exhaust valve would allow burning fuel to enter muffler.
If you could do a compression test it would indicate that one cylinder is low.
Mar 11, 2016 | Garden
What would cause the elbow and manifold to get red hot in minutes on my 2004 Ski-doo elite under normal driving conditions? Could it have blockage in the muffler?
Blocked muffler will cause extreme reduction in power. When you say red hot, do you mean it glows red or it is very hot and you will burn your hand on it? The latter is normal, you cannot touch an exhaust system within a minute of running. Cherry red sounds abnormal. Engines putting out maximum power can have glowing manifolds but not average power. Make sure the timing is correct and do not use gasoline with an octane rating that is too high. Higher octane fuel burns slower. If it is still burning when the exhaust valve opens, it will continue to burn in the manifold. Use the gasoline recommended in the owners manual.
Feb 14, 2015 | Winter Sports
Glowing Converter/ Muffler Noise/ Power Loss
your cat is plugged remove it and replace with straight pipe or replace cat
Apr 05, 2017 | 1994 Chevrolet Camaro
I have a 94 Caprice 4.3 v8 and the past week it will run fine the acts like it's not getting enough fuel back fire real loud and die and it takes bout 10 mins before it will start again then when it does...
not starving fuel but "flooding out" and putting unburnt fuel in the exhaust system which ignites and damages mufflers and cat converters
check for excessive fuel pressure or bad /leaking injectors
Jun 10, 2017 | 1994 Chevrolet Caprice
Every time i put a new muffler on my 1997 jeep grand cherokee the motor bakfires and blows the muffler compleatly apart it dosent do it right away it runs fine for a few miles then boom then it starts to...
What a funny set of events.Of course the tail pipe is clear(you would have checked that)The only other thing it might be is the cat/converter is blocked.New muffler is allowing a heap of air through and it suddenly clears and the bang.They do block up so it may be worth getting it checked.Hope this helps
Oct 31, 2010 | 1997 Jeep Grand Cherokee
CONSOLE RUNS GAMES BOUT 10 MINS CUTS OFF RED
Make sure the fan is running and make sure its clear of any dust and / or obstructions, if its cutting out after a certain period then its oveheating.
jonno
Nov 02, 2009 | Sony Playstation 3 (PS3) Console
Hot muffler
You got a couple of geniuses answering your questions. When he says it is getting red hot, he means that it is glowing red. Hot air passing through the muffler from a normal running machine does not make it get red hot, mowerman. And there are more reasons then the 2 you list mrfixit. The likely problem is your jets in the carb. It sounds like it is running to rich. Play with the little screw on the carb a bit. I think you would have to turn it in a bit. Wish you luck.
Sep 21, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Homelite ZR10926 16" Chain Saw Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
