Question about Fisher and Paykel Washing Machines
Hi my washing machine first would not spin, you had to turn it on as it turns it self off. Now it turns on but as soon as it starts to agigtate it turns power off and cant be turned back on for a few mintues. Any ideas.
    President:
  • 1,554 Answers
It sounds like there's a problem in the motor controller module or the motor itself. Unplug the machine first for at least 30 minutes to eliminate the possibility of an electronic glitch. If unplugging it doesn't address the issue, disconnect power then raise the console to access the motor controller module. Disconnect the pump and motor harness including the rotor position sensor harness from the motor controller module.
Reconnect power then start the machine. The problem is either of the disconnected parts if the machine doesn't shut itself off. Reconnect them one at a time then restart the machine and you should be able to find which one is causing the machine to shut itself off.
The problem is in the motor controller module if the machine still shuts itself off with the pump/motor and rotor position sensor harnesses. Replacing the module is the only viable solution.
Indicate the exact model number of the machine should you need further assistance. You don't have to rate this solution in order to reply or post additional information.
Posted on Jan 01, 2011
  • Jahn27
    Jahn27 Jan 01, 2011
    Motor Controller Module
I have a Kenmore top load washer, it filled with wather, however, will not do anything after that? Lid is closed and still won't agigtate, or drain
Your lid switch is bad. You should open the control panel, unhook the switch, cut and splice the 2 outside wires together (usually tan and grey colored - NOT THE GREEN ONE). Reinsert the plug, close the control panel and you'll be all set. Don't listen to anyone who tells you that you can't splice the wires - also known as bypassing the lid switch. I refurbish and repair appliances for a living and I warranty for life - I bypass these switches all the time. If you need help opening the control panel and/or doing the bypassing, you can reach me via email on yahoo - smms6776.
Jun 07, 2012 | Kenmore 24032\24036 Top Load Washer
Hello, my becko WM5100W washing Machine has stopped working, when you turn the washing machine on, the ready, wash and spin/end stay on, along with the start botton, usually it's just the start, and...
Hi Kaylee, To explain the self test/reset mode, will take a long time. Just go to this you tube site, and it will guide you through the process.
https://www.youtube.com/watch?v=8C4J3leArY0
You may have to enter the address manually.
Hope this helps
David
Nov 28, 2017 | Washing Machines
My washer began leaking last week each time I use it. I have checked all the connections, made sure all lines in and out are free from debris. Any suggestions? It sounds to me like the machine is louder so...
Hi just read your posting.Try this on your machine.Power up the machine then advance the cycle to spin.Now push the start button.Does the noise start as soon as you push the start button or when the machine turns the bowl for the spin?Is the noise a rumbling noise or high pitched squeal?If the noise starts as soon as you push the start button the fault is your pump.If the noise starts when the machine spins the bowl then the problem is with the bearings and seals.Please reply with additional information and I am sure I can help you.Looking forward to your reply.
May 23, 2011 | Fisher and Paykel GWL11 Top Load Washer
Kenmore 3-speed won't agigtate
sounds like the motor coupling could be broken
Feb 24, 2010 | Kenmore Washing Machines
Drum does a small turn then stops but wont empty -wont wash either beko 1000 rpm
Hi if your beko 1000 spin washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 23, 2009 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
