Question about Video Game Consoles & Games
VHS won't record a TV show - Video Game Consoles & Games
  • ffiore29 Jan 02, 2011
    Is my VHS broke? It won't record.it will play aVHS tape.
Did you hit the record button?
Posted on Jan 01, 2011
Testimonial: "no "
  • ffiore29 Jan 01, 2011
    Of course
Recorder stops recording from vhs tapes after about a minute
Some VHS tapes have copyright signals embedded in them. Then when the DVD recorder reads the copyright signal it will stop recording due to it thinking there is a copyright violation happening. Try testing with a VHS TAPE of a show you have recorded off the TV and see if it does the same thing .,
Mar 24, 2016 | Televison & Video
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
When recording from vhs tape, and the signal is poor at times, the machine automaticaly stops recording temporarily and resumes when the signal is more stable. how can this feature be disabled?
If you are recording VHS tapes that contain macrovision, and most commercial tapes do, you can't record them with this DVR because it is compliant with the law that says you can't do it. So don't try. Download nearly every movie/tv show from the internet instead.
If you are recording from VHS tapes that you have created yourself from TV sources, or from camera, you must stabilize the picture. There are several devices like that. Do a google search on "vhs stabilizer".
Apr 21, 2009 | Protron PD-DVR100 DVD Recorder
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
Apr 09, 2009 | Quasar VHQ400 VHS VCR
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Recording from tv
the line out from your tv has to run into the line in on vhs/dvd player
Dec 27, 2008 | Zenith XBR716
Stupid question recording on a vcr
If you have a cable box:: the RF cable from the outside to BOX, the BOX to the INPUT of vhs video, the OUTPUT of video (VHS) to the back of TV.
Keep the channel for the reception of tv through CABLE BOX according to cable box directions.
Put the ch. on the cable box to ch. u want to record...place blank vhs tape ( with the TAB in back NOT broken off ) press [record] usually red button.
Oct 27, 2008 | Televison & Video
Magnavox recorder
you casn look to see if you have a input on your remote and hit that to see if you can see something else
Mar 15, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
