Question about GE Washing Machines
Fill mode does not shut off - GE Washing Machines
  • 770 Answers
Check your fill valve in the rear it maybe stuck open also there is a pressure sw hose that goes from the tub to the timer it may have a hole in it
Posted on Jul 08, 2008
My vcr plays or records for 12 sec and shuts off then when i cut on the power it ejects the tape....also when i power the vcr with no tape a wheel is spinning in the back right corner whats wrong?
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Sep 27, 2011 | Cameras
I get error FE- book says unplug and call a tech. Is this something I can fix myself?
FE error means that the water is filling past it's set point. You may have a broken water valve that won't shut off when it's in the filling mode. You can check by running the washer and watching the water fill. If the water level fills above the bottom of the glass, you have a water valve that's not shutting off. Replace the water valve.
Aug 21, 2011 | LG WM2487H Front Load Washer
We have a dometic frig in our RV that runs on either electric or gas. Can I run it on gas while driving to the campground or do I just turn it off until we arrive?
The dometic is designed to run down the road in the gas mode, but NEVER fill you LP tank with you unit switched on, in either the gas or AC mode. Make sure you shut everything down before filling the tank!
http://67.238.126.140/pdf/3309661.001.pdf
Aug 13, 2011 | Dometic NDR 1062 Refrigerator
I have a fisher paykel GWL10 washing machine. It shuts off while
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Jun 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Water dose not stop runing and go into wash mode
Does your washer constantly attempt to fill and never does? Or, does the washer continue to fill and overflow?
If the washer is constantly trying to fill, but your water level does not change, you may have a condition known as siphoning. Siphoning occurs when you don't have a proper air gap on the drain line and the washer will actually drain as it attempts to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
If your washer fills, won't shut off and then overflows, this is caused by either a pressure switch malfuction, or a water inlet valve that won't shut off. The following link explains how to diagnose the problem:
http://www.fixya.com/support/r3753517-whirlpool_top_load_washer_fills_when_not
I know the link is for a problem where the washer continues to fill even when it is not in use, but this problem occurs while the washer is running as well. The method of determing the cause is the same. In many cases, an overflow problem is caused by the air hose slipping off the pressure switch. Without the air hose, the pressure switch never detects the pressure differntial from the wash tub as it fills and won't shut off.
Read through the links provided and let me know if you have any questions. If the conditions I have described do not match your symptoms, please post back and elaborate a bit more so I can help you determine the source of the problem. Please include your complete MODEL NUMBER. I hope you find this information helpful.
Mar 28, 2010 | Kenmore 24032\24036 Top Load Washer
2000 saab 95 wagon,2.3t. oil pressure light came on. checked and filled oil, about 2 quarts. light did not go out. driving on highway, car shut down when check engine light came on. now car will only run...
Oil pressure sensor blocked or faulty. both oil level sensor and oil pressure sensor activate the oil light. engine goes into safe mode and shuts off ignition.
Mar 04, 2018 | Saab 9 5 Cars & Trucks
Johnson 1998 175 hp motor seems to be in safe mode
U CAN DISCONNECT THE OIL RESOVIOR SWITCH THAT TAKE IT OUT OF SAFE MODE BUT IM LEANING TOWARD THE POWER PACK
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Will not wash it syphons water in the wash mode
The mixing water valve isn't shutting of letting it come in slowly. Replace valve. If not filling up may be caused , drain hos emaybe to low to ground. Should be at least two thirds up the washer.side.
Jun 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Model# 110 20902990 kenmore washing machine over flows
hi thanks for the question you could have a water valve problem how do you shut the water off by unplugging power cord or shutting off water supply if its unplugging the power cord you have a problem with water control switch or lint is caught in small plastic tube that goes to the water level switch check that could be no parts needed thanks the appliance doc
Sep 27, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
The Computer has trouble restarting Windows XP. I have to shut it down and unplug it for at least 2 minutes in order for it to start normally past the black screen. Otherwise, it will keep restarting...
I'm guessing from what you are saying, that it will in fact boot to safe mode. the culprit is most likely a resently added program. my other favourite is thermal shut down. remove the cover (after it is shut down and power is removed) and see if it's filled with dust and dirt. when the case is off start the computer up. are all the fans working as well ?
Robert
Aug 27, 2008 | Computers & Internet
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
