Question about Cyberhome CH-DVD 300 DVD Player
When i place dvd in to play movie it reads disc then displays dvd but no picture or sound
  • latoosa Jan 01, 2011
    yes i had a picture for a minute but when i put in another dvd it went back to no picture with a cd it skip plays all tracks guess it needs a new laser thanks.
    thanks i had it playing but when i changed discs it went back to no picture or sound guess it needs another lens.
  • Cyberhome Master
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
Posted on Jan 01, 2011
  • Walesarumi
    Walesarumi Jan 01, 2011
    You are welcome!
Sony tv will play copies of movies from tv, but won't play store bought new ones. I mean current popular ones. It played Avatar last week but won't now. We tried several new movies and none will play. Put...
There is some confusion in the explanation here.
The TV does not play movies it displays them It is the DVD that Plays them. But of course you knew that. Some of the newer movies like avatarcan be on Blu ray if your DVD is supposed to play Blu ray but doesn't don't be surprised as they have changed the format recently. Your DVD will require an udate of firmnware. Go to the website of the DVD brand and contact support Download the update and burn it to a disc and run it.
With the TV end Make sure the resolution can be accepted from the DVD you are trying to Play. If it isn't HD or capable of 1024x768 at 16.4 then it may not be able to display the image. Is there any sound?
If sound but no Pic then start playing with the picture format. go to 8.2 or 4,0 to see if it makes any difference
Please rate my help++++Thanks for using FIXYA
May 16, 2010 | Televison & Video
Dmr-ES30V Dvd plays pre record movies fine but I
Try a different brand of blank dvd+r or -r. you will find that your dvd machine is fussy on what discs it plays. More exspensive dvd players are fussy with what dvd discs you put in, as cheaper dvd players would virtualy play most types of dvds.
Dec 09, 2009 | Panasonic DMR-ES30VS DVD Recorder/VCR
Bose system plays sound to movie but not reading dvd, no picture
If you can hear sound the DVD must be playing. Check your video output settings,wiring and display.
Jun 05, 2009 | Bose Lifestyle 28 System
I put a disc (dvd) in and it will start saying it's reading the disc and then will tell me no disc is inserted. CD's play well and so do picture DVD's. But no movies. The movies are brand new and not...
Picture dvds are read with different software than that required to play movies. Make sure that you actually have dvd player software installed on your system, like WindDVD or Power DVD. See this link for a few.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 30, 2009 | Audio Players & Recorders
Panasonic dmr-eh75v dvd won't work
dirty lens, broken ribbon connections or adjust the bias of the lens place at the back of the lens.....
May 08, 2008 | Televison & Video
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD PLAYER NOT READING DISC
Well I have been repairing dvd players a while now and the main problem spots are laser ,spindle motor, laser tracking motor and the biggest culprit and un suspecting one the lens cable .....most of them range from the lens cable to the spindle motor though... the constant movement of the lens in watching a whole movie causes the cable to unknowingly and slowly break and if the spindle motor is defective ,on inserting a dvd the disc spins slowly and you may hear the lens chirping ... so you can check those....
Oct 06, 2007 | Onkyo DV-S535 DVD Player
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
Disc cannot be played
TRY TO RELACE YOUR CD OR OPEN YOUR CD DRIVE THEN CLEAN THE LENS WITH A COTTON OR ADJUST THE TRIMMER
Apr 19, 2007 | Samsung L70 7" Portable DVD Player...
Cyberhome CH-DVD 300 DVD Player Logo
570 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Electro Med Services...
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
