Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite refrigerator
Just bought new kenmore ss refregerator on top freezer on bottom and it does not get cold. what is the problem? Kenmore Mod.596.79272992. Bottom freezer works ok, but refrigerator will not cool below 60 degrees. Everything is clean underneath.
Could the problem be the thermostat or something else?
  • 1 more comment
  • KTChrist Aug 24, 2008
    The freezer in my Kenmore Elite Is fine . The Top refrigerator is freezing the food. I am mixed up . What should the temperature setting be on ?Please help I am losing all my food.
  • rombo67 Dec 05, 2008
    Model 596.76523500 Fridge-upper Freezer-lower
    Freezer works great but the fridge (upper) quit cooling yesterday. It stays at 63 deg.. I have gone through the troubleshooting manual and addressed all "solutions". Out of warranty. Any other ideas?
  • Anonymous Jan 11, 2009
    I have the same problem
  • 2,326 Answers
If this appliance is new, I would suggest to contact the vendor or manufacturer and ask them for in home service.
It could be the thermostat that might be not working properly or not set properly.
Check the user manual for more info on the thermostat settings.
Posted on Jul 08, 2008
    Master:
  • 788 Answers
It sounds like the fan is not circulating the air from the freezer to the fridge. Since it's new then you should contact the store where you purchased it for exchange or repair immediately.
Help please - my Kenmore Elite Bottom Freezer not cold - top refrigerator getting warm.
Have pressure taps installed, & check the refrigerant... these refrigerators have a critical charge (meaning not a lot of refrigerant to make them work) So whoever puts gauges on it, make sure they purge their hose while screwing the hose on to the new pressure tap so there is no loss of refrigerant & no air gets into the system. It sounds to me like it is low on refrigerant.
Dec 10, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have Kenmore Elite 59673503201 freezer fan went out replace then it started freezing at the bottom of the refrigerator put in new vent control at the top of refrigerator still doing the same thing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 17, 2012 | Kenmore Refrigerators
Top not cold but bottom works fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer - only top does not work
i would check to see if you hear a an blowing in the freezer sect when the door is opened, if you cant hear the fan blowing then there is yout issue, not circulating air up to refrig compartment
Nov 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Trio Elite 596.75529400
Has anyone got you a solution? I think I have the same problem with mine!
KSheridan
Oct 27, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
471 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
