Question about American Standard Garden
Where can bay ingnition coil for Talon F460 surefire 145 serial no-08010115
Where can I get a set of rings for a talon silver eagle sure fire 145 model am3058
get the bore size and ring thickness and go on line to the catalogue for mogul rings or other ring manufacturing companies. Rings are not made specifically for an engine so rings from another make of engine with the same bore size and ring thickness will fit.
Feb 08, 2015 | Eagle Cars & Trucks
Fuel hoses and filter need replacing and a spark plug for a Talon AT3351A line trimmer
The manual has some instructions for doing these tasks on the Talon At3351a Line Trimmer. Here is the link for the Talon At3351a Line Trimmer manual.
Jan 21, 2013 | Garden
Getting juice to coil but nothing beond the coil to plugs help please its a 1995 talon 2.0 turbo
Are you getting no spark from all the coil outputs?
If so, then replace the coil.
Nov 13, 2012 | 1995 Eagle Talon
96 eagle talon turbo. p-302 code ,#2 cylinder misfire . cleaned and tested injectors , replaced plugs and wires no vacuum leaks , 145 psi compression ...stumped ...
Get a spark tester preferably one that you can gap at 10, 20, 30, 40K's. Then compare the maximum spark that you can get out of one of the good cylinders against the bad one. It may not be doing it's job.
Jun 17, 2011 | 1995 Eagle Talon
Lost ingnition key cheapest way to go
replace the ignition switch or call alocksmith
Sep 18, 2010 | 1990 Cadillac Deville
I replaced the battery in my surefire E1B light. Nows it will not come on.
You can call up Surefire www.surefire.com and talk to Tech Support, they are real good about backing up their product.
HEADQUARTERS
SureFire, LLC
18300 Mount Baldy Circle
Fountain Valley, CA 92708
Toll Free: 800-828-8809
Outside the US: 714-545-9444
Fax: 714-545-9537
Guarantee/Warranty
May 22, 2010 | Surefire E1B Backup LED Flashlight
Why my 97 eagle talon send only spark 2/3 but 1/4
YOUR COIL PACK IS FAULTY ON 1--4 AS THE FIRING ORDER IS 1342 SO 1-4 AND 2-3 fire togeather so the coil on 1 and 4 is the one not working
Oct 05, 2009 | 1995 Eagle Talon
Pacific Digital TALON ZL-2 Serial ATA Controller driver
I have the version 1.0 drivers, email me and I'll send them to you.
j-s-t-r-i-k-e@hotmail.com
(Remove the -)
Dec 10, 2008 | Pacific Digital TALON ZL-2 (u30244) Serial...
Fuse box location
the fuse box for the esi is in the engine bay near the battery
Aug 15, 2008 | 1996 Eagle Talon
Garden Logo
56 people viewed this question
Top American Standard Garden Experts
Dennis Key
Dennis Key
john h
Are you an American Standard Garden Expert? Answer questions, earn points and help others
