Question about Nintendo NES Console
Hi, I had issues with a solid screen on my nintendo so i replaced the 72 pin connector cleaned the contacts on the mother board before installing i also cleaned my games. After all that i tested my console and still have a green screen but i can hear the game start up i just cant see it due to a solid green screen so hopefully u can give me some advice. Thanks, Billy
    President:
  • 894 Answers
Well it might have a bad capcaitor and it needs to be replaced then.
Posted on Jun 16, 2011
Nes displays solid blue screen after i installed new 72 pin connector
Try cleaning the game packs out with qutips and rubbing alcohol too and the game port is dirty too try cleaning the game port out with compressed air cans.
Jul 23, 2012 | Nintendo NES Console
Solid yellow screen that is not flashing. I replaced my 72 pin connector and made my nes region free (4th pin from the left on the nintendo chip). I can play Super Mario/Duck Hunt but every other...
Well I think that the capacitors might be broken then and need to be replaced. Or try cleaning the gamepacks out with qutips and rubbing alcohal.
Sep 21, 2011 | Nintendo NES Console
Hi, My nes only displays a white screen when switched on with a game inserted. I have changed the 72 pin connector to one which I know works, cleaned the contact points the connector slides onto and used a...
Hi, probably need a new 72 pin connector, or you have bad capacitors or broken traces. we fix all those, check it out www.consolesolutions.net/nes
Aug 27, 2010 | Nintendo NES Console
Hi, I have a Nintendo Entertainment System which I found laying around a couple weeks ago. It wouldn't work at first so I replaced the 72-pin connector. It worked perfectly until recently, when I turn the...
It is probably a bad chip on the main board.I used to work at United Radio in Syracuse,NY on Nintendos and would see that.I forget what the charge is to repair an NES,maybe $40?There should be a sticker on your console with the phone number to Nintendo to ask them about it,or you can google Nintendo to talk to them.If you send everything,they will replace the controllers,replace the board,and clean the games.It's up to you to determine if it's worth it.When I was younger,we used to take and cut a slim piece of paper,about 1/8-1/4" thick and put it over the pins and stick in the game.On Mario,it used to show you where all the hidden stuff was,if you got the right spot.Good luck!
Jul 19, 2010 | Nintendo NES Console
I have changed the pin connector on my nes, it does not flash anymore but now i get a blank screen can someone help me?
First try connecting through the av ports on the side of the console rather than the RF port on the rear of the unit.
If that doesn't work then your problem is likely a loose connection inside, go back in and reassemble.
I have had this issue with several consoles; these two solutions usually take care of it, though in rare cases a defective 72 pin connector was at fault even though it was brand new.
Good luck.
Mar 31, 2010 | Nintendo NES Console
I have installed the 72 pin, but the graphic, seem to work but dont quite line up, it is like the graphic are squares and distorted
The cartrage might not be inserted right or the 72 pin connector isnt lined up right so i would try installing it again.
Jun 29, 2009 | Nintendo NES Console
I replaced the 72 pin connector in my Nintendo Nes and now I just get a grey screen? what can bee the problem? Cecilia
You may have damaged something on the board during the process. I suggest going over what you did, making sure the 72 pin connector is seated properly so the connection can be made cleanly, and if all else fails snag another one on ebay and try again...
Nov 26, 2008 | Nintendo NES Console
White dotted lines on screen of NES
Clean your games too once you replace the 72 pin connector or you're just dirtying it up again. Not to mention the games has enough crud to keep them from working correctly.
Mar 28, 2008 | Nintendo NES Console
Nintendo NES Repair
It's as simple as unscrewing the console by removing all the screws from the bottom. Once inside take off the metal piece over the area where the game is inserted. Once under there you can remove the two screws that hold the 72 pin connector in and pull it out and slip a new one in. Put it back together in reverse.
Mar 26, 2008 | Nintendo NES Console
Nintendo NES Console Logo
155 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
