Question about Toys
I got my s107 a week ago it worked perfectly, but then I did not get more than a foot off the ground I started fiddling with the screws I made a little bit of a difference but eventually in the first minuet of flight it drops to a foot above the ground again!!! PLEASE HELP :(
  • 1 more comment
  • jak salt Jan 05, 2011
    firsI got my s107 a
    Problem with the Toys
    I got my s107 a week ago it worked perfectly, but then I did not get more than a foot off the ground I started fiddling with the screws I made a little bit of a difference but eventually in the first minuet of flight it drops to a foot above the ground again. It started to work again then i started flying it in the dark and now is losing altitude rapidly what do??
    i dont think that was the problem because it was working working fine again but than i flew it in the dark and when i took it back into the light it started falling rapidly
    thank for the help!
  • jak salt Jan 06, 2011
    And now it wont even fly. the rotor dont move and the charge light is green!!!!
4 Suggested Answers
  • 10 Answers
SOURCE: My S107 worked fine the
Seems like your controller is not working. Try to change its batteries.
With new batteries try the following:
1. Turn the controller ON. Wait until green light stops blinking.
2. Turn the helicopter ON.
3. Give it throttle few times until it starts working.
Sometimes controller can still work even if has a blinking light. But these cases are very rare.
Posted on Apr 09, 2011
SOURCE: hi, my syma s107 worked great for many
Very important with these motors and the batteries is a solid 5-10 minute rest after charging and after flying. Make sure the shaft is fully seated. Push it down firmly (but gently) both above and below bottom rotor.
Let me know if this doesn't help.
PvT
Posted on Sep 14, 2011
  • 3 Answers
SOURCE: After 3 weeks of perfect
Mine is doing the same - after a closer inspection, I found two tiny plastic pins broken. The pins are on the inner shaft and hard to see because they are normally on the inside of "picture frame" that holds the upper blades.
These pins do two things:
1) They provide the turning torque on the upper blades
2) They hold the upper blades at the correct height on the shaft relative to the balance bar
Without the pins in place, the blades are being turned by the tiny linkages to the balance bar, with the result that the angle and height are incorrect. This is an unbalanced gyro, resulting in the toilet bowl effect (very aptly named!)
Posted on Dec 26, 2011
Why was my drone flyiing perfectly fine and now it wont take off at all
I know this is new but it sounds like a battery pack issue. Replace the batteries and I bet you will be fine.
Feb 18, 2016 | Toys
Change frequency chamberlain
YOU HAD IT IN THE SUN,it is burnt out now
Jul 22, 2013 | Alert Driveway Alarm System
HEATER/DEFROSTER FAN QUIT WORKING
Could be the blower motor, or the resistor, or a bad connection in the harness. Someone would need to check for power and ground at the motor first.
Dec 11, 2012 | 2002 Chevrolet Silverado 1500
S107 RC Helicopter making a high pitched whine when used
If the gears are meshing properly and the rotors are not spinning very fast then the motor shaft is slipping in the hub of the first gear.
Jun 11, 2012 | SYMA Toys industrial New Syma S107 Mini...
My Syma S107 will not lift off the ground. what can i do to sort this out?
Had the same problem - the rotors would spin but the helicopter would not take off. Finally tried tightening both screws on the piece just below the Balance bar. I tightened one of the screws about 1/8 turn, and now it works great.
Dec 05, 2010 | SYMA Toys industrial New Syma S107 Radio...
Replaced ignition switch on 2001 chevy malibu now a/c, power windows, gauges inoperative
ok first off my 2001 malibu was screwing up over 8 months ago was sent to a garage and was never looked at....went and retrieved the car and it worked perfectly for 2 weeks then its starts again... check engine light keeps coming on... radio, heater and power windows stop working...it is in the ignition and how can this problem be solved
Sep 01, 2010 | 2001 Chevrolet Malibu
Rebuilt top end 300 and now idles fine but when give gas it bogs down and stops
hi mate on the carb there are 2 screws below picture will demonstrate on the mixture screw you need to fiddle around with it either screw it in 1/2 turns and see if it improves in not unscrew it a full 1 turn just fiddle with it till it runs perfect also try replacing plug d730aae.jpg
Aug 27, 2009 | 1998 kawasaki KLX 300
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toys Logo
69 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
