Question about Behringer Ultratone K1800fx 180w Keyboard Amplifier New
Lot of noise through the amp without any leads plugged in. I simply turn it on, adjust the EQ and it starts to crackle without stopping.
  • Behringer Master
  • 5,603 Answers
Just repaired a similar problem on a GX110. There was a ribbon cable to the effects board that the IDC connection was poor... move the cable and loud crackle. If you open the unit look for a ribbon cable about 1.5 inches wide going to a squarish shaped board. Wiggle it and if noise is there, squeeze the cover on the cable at the board end which is a fixed (doesn't come off) soldered in termination. Wiggle it and warm with a hair dryer to get wires seated.
Posted on Jan 01, 2011
Why is there a faint crackle from the amp when I strum?
Assuming that the problem goes away when you plug a differebt guitart into your amp, you have a loose ground somewhere in the guitar.
Aug 09, 2015 | Music
Why is my Fender Blues Deluxe Amp making a crackling sound without an instrument even plugged into it and when I do plug in, it quiets when I touch any place on the guitar?
You probably need a new input jack on the amplifier. When they get loose the connecting wires can crackle, but plugging a guitar in stabilizes them (no more crackle).
Feb 11, 2015 | Fender Blues Deluxe Reissue Tweed Combo...
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I turn my fx off but can still here it and the od sound is lower than the fdx button when i push it in to turn it on
2 things 1: there is no off button for the built in digital effects, you just turn the level down to minimum, the fdx button you speak of is actually fdd (frequency dependant damping) this is supposed to mimic how a tube amp sounds
2: when you press the od switch the amp goes into hi gain mode and will hiss with no input, the point is if you plug a guitar in and play it the volume of the guitar is way above the hiss and you don't hear it
so in conclusion having bought and sold many mg series amplifiers the on you have is perfectly ok
Mar 10, 2012 | Marshall Mg15dfx 15-Watt Combo Guitar...
My peavy kb300 produces a crackling noise & cuts off intermitently when I raise the volume on all 3 chanels.
Low Voltage power supply regulation issue, particularly with +15V and -15V.
Dec 23, 2011 | Peavey Music
Buzzing noise when not playing
All amplifiers make a little bit of noise (hiss) but it is normally slight and drowned out by playing. However, assuming that this is not normal system hiss, here are a few simple steps to try and locate the source of the problem by process of elimination.
  1. SAFETY FIRST - a common cause of a humming or buzzing sound can be a lack of earth (grounding) on the mains supply. With a 240volt AC supply this hum will be at 50hz (in the UK) - frequency may vary in other countries but should be similar. Check the earth first because of risk of electric shock. Until you are satisfied that this is not the cause of the problem DO NOT touch any metal parts of the amp. Remove the mains lead and try a different one. Try plugging the amp into a different mains outlet socket (preferably one on a completely different circuit).
  2. Turn off other electrical equipment in the vicinity that may be causing interference. Move the amp a bit, try rotating it by 90 degrees to change relationship to things like mains electric cables in the floor.
  3. If you are using the line-out socket to give a feed to a mixer, slave amp or p.a. system unplug this. Sometimes double earthing (through the mains lead of your amp AND the mains lead of the MIXER / PA) will cause an 'earth loop' due to a different resistance at each end. Putting a DI box with an 'earth lift' in between may eliminate this problem. Alternatively there are little gadgets you can buy to do this (I found one intended for car audio systems on Amazon that works very well)
  4. Unplug any instrument leads - to eliminate possibilities of interference affecting cables, effects pedals or guitar pick-ups. Also unplug the foot-switch.
  5. If that stops it plug a lead in without a guitar on the other end - does the noise return? If yes change the lead. If no plug the guitar in.
  6. Try moving the guitar in relation to the amp (turn it around 90 or 180 degrees) - this will be pick-up to amp power supply interference.
  7. Does the sound get better or worse if you touch metal parts of the guitar with your hand? This may be a screening issue within the lead or the guitar itself.
  8. Try turning all the individual channel tone and gain controls to zero, turn off any effects on the amp panel. If that eliminates it only turn up the controls on channels that you are actually using.
Jan 30, 2011 | Marshall Amplification Marshall MG50FX 50...
How to set up with amp and distortion pedal
With everything switched off. I will surmise that you are using the onboard battery with the foot pedal and not a power supply.
1. Plug lead from guitar/instrument into INPUT side of pedal
2. Plug lead from OUTPUT side of pedal into amplifier INPUT.
3. Turn amplifier volume to about 10 o'clock - to stop blowing your ears out.
4. Turn volume up on guitar to acceptable level.
5. press foot switch on pedal and adjust pedal controls to suit your type of distortion.
6. Play like Hendrix.
Good Luck
ps Just as an after thought rechargeable 9volt batteries are the way to go. I've been using them for years as I always get caught up in the power cable.
If you're going to add another pedal like a Phaser, Compressor, Flanger or what just use small connect leads between each pedal but always, always put the compressor pedal last in the line.
Sep 12, 2009 | BOSS AUDIO SYSTEMS Boss Ns2 Noise...
Behringer Ultratone K1800fx 180w Keyboard Amplifier New Logo
204 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
