Question about Easy Heat Water Pipe Heating Cable
We have no water and not sure if heating cable has failed or the thermostat.thermostat appears to be working how can I check to see if its the cable model # SL1. LR18321
Error code E8 appears mid wash, heater is working ok, machine has been hooked up to the hot water instead of cold. I have since directed cold water through water valve.
hot water form the house takes less power to bring up to machine temperature so by hooking it to cold water will increase the power consumption
call a service center and get the explanation for the error codes and that will explain what is faulty
you didn't mention the make and model of the unit and every error code appears different
for example in a fulgor milano machine code 8 is failure of orientation of distributary valve ===causes open circuit or break of distributary valve
for hoover nextra e8 is dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element===causes check water heating element/wiring--check wiring to main control module
go google and type in-- dishwashing machine error code 8-- and see if there is any site for your machine to get the error code and causes
other than that get in a service technician for a correct diagnosis and fix
Apr 23, 2016 | Dishwashers
2001 DEVILLE HAS NO LEAKS BUT RUNS HOT. WHAT IS THE PROBLEM,WATER PUMP OR THERMOSTAT.
I would change both first get a fail proof thermostat that way it would never over heat put it in and see if you got heat. if you got heat thermostat is good and water pump check your fans and make sure coolent is full make sure oil looks good you don't want to over heat that car or you will burn hea
Jul 11, 2014 | 2001 Cadillac DeVille
I have an Aqualink system, spa set to 104, it will heat to 94 and stay there, temp sensor is working, took water sensor out of line, plugged line, assumed heater would just keep heating, it did heat a
The heater may be wired just fine. The aqualink uses its water temp sensor to call for heat based on what you've set the thermostat to on the aqualink. However, most heaters have built in thermostats that over-ride the aqualink. Those thermostats come factory defaulted not to go over 94. Check your heaters manual on how to adjust the thermostat on the heater. Your heater should have its thermostats set to 104 and the aqualink will control the actual temp of the water by calling for heat based on what you've set the thermostat on the aqualink for. Hope this helps.
Oct 16, 2012 | Jandy Aqualink Rs4 One Touch Control...
My 1999 jeep wrangler is over heating, smoking and losing coolant , I replace the heater core, replace radiator, replace thermostat and thermostat housing still over heating
It appears that you have a blown headgasket, a failing water pump, or a cracked block.
There is also the possibility of a freeze plug failing & leaking there.
You can bypass the heater core until you are sure your engine problems are corrected so as not to damage it from excessive pressure.
You'll need to reassemble everything and pressure test the system instead of starting the engine, to see where the leaks are.
Good luck !
Mar 28, 2012 | 1999 Jeep Wrangler
My Dodge 2005 Ram overheats on hot days while running the AC. If I turn the heater on then it cools down. I need to know if this is a thermostat problem or if something else.
I see your post was a while ago. I hope this helps you or anyone ells having Dodge over heating issues.
I have a 2002 Dodge Ram 1500 and a 2005 Dodge Grand Caravan. I also owned a 2001 Dodge Grand Caravan. ALL of them had thermostat issues. When you replace the thermostat make certain you get the proper heat rating. If it is rated tool low, then the check engine light will trigger the code that the engine is not heating up fast enough. I also recommend going with a 'fail-safe' thermostat. These thermostats fail OPEN rather than closed. My 2002 RAM factory thermostat failed closed, built up pressure, then blew half the water out from under the radiator cap. This happened in less than 35k miles. The dealer replaced it. After a couple of years it failed again. Make sure you have 50/50 mix of anti freeze to water. This raises the boiling point of the water, makes it more efficient for cooling the engine, treats the water so it does not corrode and scale up the cooling system and helps keep the liquid from boiling off there by reducing the volume of fluid in the cooling system. Also, BOTH my 02 RAM and 05 caravan developed a leak in their radiators. They were slow leaks and I did not notice it until I did some standard checks and found the coolant was low, Most shops can run a pressure test for less than $40 to let you know if your radiator is leaking.
You should also make sure that your AC cooling fans is running. There are fuses and solenoids in the fuse box that can sometimes go out. When you AC is on this fans will turn on. If not, it could create a lot of extra heat.
Shawn
May 30, 2011 | 2005 Dodge Ram
Oven is not heating. Fan is working and grill wor...
This would appear to be the ring element around the fan that has failed and will need to be replaced.You will need to power off unit,then remove the back panel inside oven 4 screws in corners,Be careful with Thermostat held in place by clips above or on back panel.You may find 3 or 4 screws holding ring element.Gently pull towards you,being careful that the cables come with it.Check element with multimeter to see if open circuit if its ok then it may be a thermostat fault.If it is a faulty element,
get your replacement element,remove the cables off old one and put onto new one.Then push back into place and refix all.
Hope this helps.
May 21, 2010 | Electrolux EOB6630 Ultrafan Electric...
No heat from the heater, then the car overheated and was leaking water out of the thermostat housing.
1. the heater always fails first when you lose water.
hence you suffered large amount of water loss.
causes,
first check for any leaks = fix
thermostat stuck closed = replace
electric fan failed, check switch is working
then
CHECK THE HIGHT OF THE HEATER MATRIX IN THE CAB , IF ITS HIGHER THAN THE FILLER/EXPANSION TANK. THEN ITS AN AIR LOCK, LOOK FOR THE HIGHEST PIPE AND SEE IF THERE IS A BLEED VALVE, IF NOT TAKE BOTH PIPES OFF THE MATRIX FEEDS AND FLUSH OUT TO SEE IF IT IS BLOCKED, AND RECONNECT LOWEST PIPE FIRST AND FILL SYSTYM TILL WATER APPEAR FROM TOP AND RECONNECT RUN MOTOR, AND KEEP TOPIN UP
Dec 05, 2009 | 2002 Dodge Intrepid
Vaillant boiler no central heating but hot water ok
Could be a lot of things, but the issue appears to center on the heating circulation system. Possible causes I can think of:
  1. Thermostat setting is incorrect
  2. Thermostat is failing
  3. Main circulation pump for heat has failed
  4. Valve for heat circulation is closed
Oct 24, 2009 | KDS Valiant 6380iPTD-01 Notebook
E1 fault code Dishwasher runs for about 5 minutes. Water fills up at bottom of unit and then machine seems to pause then fault code E1 appears then water is pumped out from bottom of machine. There are...
I think both the heater and thermostat / trip switches need to be checked.
If water is going in and out ok, then it seems to be waiting to heat the water. It sees a fault - so just clears out.
Heating elements do fail after a few years.
Aug 05, 2009 | Dishwashers
LG dryer model DLE0442W...brand new. no heat. had the thermostat replaced. it worked while the repair guy was here. put a load in and left for the day. came back and the load is wet. now it won't...
Hi, I'm not sure this will correct the problem but check to see if your dryer is properly grounded. It should be grounded to the cold water pipe.
It does sound like the thermostat would be the problem. I'm not sure why it is failing. Sorry I couldn't be more help.
Aug 30, 2008 | LG Dryers
Easy Heat Water Pipe Heating Cable Logo
75 people viewed this question
Top Easy Heat Plumbing Experts
Paul Carew
Tom Chichester
Are you an Easy Heat Plumbing Expert? Answer questions, earn points and help others
