Question about GE GSS25LGM Side by Side Refrigerator
I have a GE side by side and it just stopped working? My GE side (model pss26mswass) by side stopped working and it has no power and nothing is running. I check the house fuse pannel and no breakers are tripped. Also I pulled the fridge out and tested the wall outlet and there's power to it (i used a small radio and it works when plugged in there). Any help would be appreciated.
  • mlisgaris Jan 01, 2011
    Macmarkus,
    Thanks for the info, I appreicate it. BTW, I am a big Maiden fan also!
    Mike
  • GE Master
  • 2,605 Answers
Welcome to FixYa,
Unfortunately based on your post ( has no power and nothing is running. I check the house fuse panel and no breakers are tripped. Also I pulled the fridge out and tested the wall outlet and there\'s power )
the issue is likely the control board (PCB) at the back of your fridge.
If you slide the fridge out and look at the back you'll see a square panel approx. 4"x5" held by four screws ( sometimes three ) remove it and you'll see this control...
It should be available ( part # WR55X10942 ) at "repairclinic.com" or "searspartsdirect.com" to name a couple for about $150 or so and come with a guide to install it, though it should be harness for harness & wire for wire.
Thanks for choosing FixYa and good luck. Let me know how you make out or if you need further assistance and I'll help in any manner I can.
Regards,
Macmarkus :)
Posted on Jan 01, 2011
  • Mark MacDonald
    Mark MacDonald Jan 01, 2011
    Awesome Mike !
    I've been a fan since around 1982-83, but I love mostly the stuff pre 1990, but I'm a fan of all of their stuff really...I play drums in my spare time, I'm no Nicko or Burr though ha ha !
    I just got the Flight 666 dvd for xmas, it's like being back in 1985 with my buddies all over again...many good memories back on the eastcoast.
    Anyway, back to the present...Let me know if I can help you going forward with the repair.
    Regards, ( up the irons \m/ )
    Macmarkus :)
Water in side by side door stopped working ?
got a problem alright
water may have got to the electrics
needs a GE authorized repairer to check
safety first
turn wall power switch off and unplug from wall
if desperate buy some bagged ice to preserve fridge contents
Oct 14, 2016 | GE Refrigerators
My GE Model 25 side by side refrigerator stopped working.
check the power supply if the is ok check thermostat and compressor
May 11, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigrator stop working
If there is nothing operating but the lights you are going to need the board linked below which is for your model.
Main board
May 22, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore model 596.71103101 stopped working. No sounds at all, no cooling. Un plugged for awhile, plugged in, still nothing, cranked freezer control to Max, started working
Sounds like a defective cold control thermostat. Remove the wires from the thermostat and jump them together. If it runs continuosly for 45 minutes, replace the thermostat.
Sep 19, 2009 | GE GSS25LGM Side by Side Refrigerator
GE side by side refrigerator model GSH25KGREWW
You said that the control board on rear of your refrigerator was replaced and there is still nothing happening? You do need to check the power behind the refrigerator to make sure there is power, yes.When did the control board get replaced and was it new?. Sea Breeze.
May 28, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Fridge stopped working
Sounds as if the unit is stuck in defrost. How old is it? Look for mechanical {twist} timer and turn it until it starts. If it is a newer model unplug unit for 1 minute this might reset control board but you'll have to know if it is either mechanical or Automatic defrost!!
May 27, 2009 | GE GSH25KGRWW Side by Side Refrigerator
GE Profile icemaker will make ice but won't dump into the tray
GE uses an electronic icemaker that is not field serviceable. if the Icemaker is getting water then something in the icemaker has failed and the complete icemaker must be replaced. the part number is wr60x10093 I believe and can be purchased online and many different places or thru local appliance parts supply house. thanks peyton
Feb 18, 2009 | GE GSS25LGM Side by Side Refrigerator
Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
Fridge stop working
You need a volt/ omh meter or call a repairman.. need to start at the control board and check power going out of the board. sounds like a board problem with out more info
Sep 03, 2007 | GE PSS26NGPBB Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
82 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
