Question about Panasonic Cameras
I have a Panasonic PVGS19 Mini DV Camcorder. The problem is the flip screen. Will not work when fully open. There is a picture when it is opened at about 1/4 of the way. Also, when opened and flipped over ( self portrait mode) and closed the image is upside down. Thinking it is a mechanical connection between the camera and the LCD that either need some cleaning or repair. Can I do this myself? Not cost affective to have repaired by service, I am sure. Thanks Bob http://www.fixya.com/lpregister2.aspx?brdid=47&cmpid=5270208079791&ctgid=0 Get Assistance
  • 4,234 Answers
There is a small flat ribbon cable between the camera and the LCD display that probably has a small crack in it. Move the cable the right way and it works. The cable neds to be replaced. This is NOT a repair to be done by anyone without prior repair experience as there are too many cables and connectors that can be damaged easily.
The repair shouldn't be too much as the hinge with the cables (part number LSXY0764) is only $17.14. Add in the local labor rate for the total repair cost.
Dan
Posted on Jul 08, 2008
I have a Panasonic PVGS19 camcorder. My computer does not recgonize it while connected through USB. I can not find drivers for Windows 7. Any help?
I am sitting here trying to do the exact same thing with my Panasonic PV-GS19. Only I am using Vista, but I am having the same problem.
Dec 29, 2010 | Panasonic PV-GS19 Mini DV Digital...
Hi, I have a Panasonic NV-GS17EB.It is working perfectly fine and a nice camera. But recently the LCD view finder is giving some problem. It goes blank when I open the LCD view finder fully. But it...
the ribbon cable that carries the signal to the screen sounds like it has become damaged
thatcan cause the problem
when it is all the way open it stretches the cable resulting in a gap to form, so when only open part of the way there is still a signal. see if there is anything in the hinge that might be causing the stretching of the cable, as that is almost surely the problem..
Dec 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
I have panasonic PV-GS32 camcorder. The lcd was working fine for 2-3 years but suddenly stopped working. If i flip open the LCD screen then the viewpoint also goes blank. Is there some setting that needs...
It does look as if your LCD screen is dead, they are not cheap to replace, but you could pop it in to your local Camera shop, they will mostly be glad to help you.
Jun 16, 2010 | Panasonic NV-GS17 Mini DV Digital...
Panasonic pv-gs15 will not play back recorded video in the mini dv deck. all i see is a blue screen with red text ''picture'' on bottom right corner of the screen
Make sure your tape tab is open. See if this works. Sometimes the tab should be closed to prevent eraser or recording over existing film but sometimes the tape tab has to be open to allow for playback or dubbing?
May 28, 2010 | Panasonic Palmcorder PV-GS15 Mini DV...
When i flip open the side view finder, i get a blank screen. it works only when the screen is half way open.
It sounds like the ribbon cable has worked itself loose either on the flip or the main body of the camera itself.
If you are confident that you can can take the camera apart and check the cables then all you will need is a set of precision screwdrivers, patience and steady hands as you will be working with delicate parts.
If your not confident with repairing yourself then i recommend that you take the camera to a specialist.
Regards.
Nov 09, 2009 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic PV-GS31
Sound like the wires running to the screen have a short or they become disconnected
Jun 23, 2008 | Panasonic PV-GS31 Mini DV Digital...
Panasonic 24x optical zoom nv-gs25
The screen went blank on my Panasonic PV-GS 19. Why so, and how to reset?
Feb 01, 2008 | Panasonic NV-GS25 Mini DV Digital...
LCD screen goes black when opened
the flex wire of the lcd monitor is already cut ...go the service center for replacement of the flex wire...or to the other service center for fixing the flex wire...it is to difficult to fix the wire if you are not a technician cause that wire is like a strand of hair...
Sep 07, 2007 | Panasonic PV-GS19 Mini DV Digital...
Camcorder LCD screen only operates up to 30 degrees from camera
open the unit. find the flat flexible connector to the LCD and then look at each end to verify if fully inserted into its mating connector.
May 30, 2007 | Panasonic NV-GS15 Mini DV Digital...
Cameras Logo
75 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
