Question about KitchenAid KUDS30IVBT Builtin Dishwasher
PUMP MAKES A SWOOSHING SOUND WHEN IN WASH CYCLE.
Kitchenaid kuds02frss1
The wash pump and drain pump are different. So it is likely the wash pump is choked and trips or the motor is faulty.
http://www.searspartsdirect.com/partsdirect/part-model/KITCHENAID-Parts/Dishwasher-Parts/Model-KUDS02FRSS0/0593/0130000/W0602076/00008?blt=06&prst=&shdMod=#
It is likely the flap valve (item 5) or the chopper (item 6) are damaged and could be replaced before you get to the wash motor.
Apr 17, 2014 | Dishwashers
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
My washer fills and agitates, but when it gets to the rinse/spin cycle it stops and makes a loud grinding noise. Thanks for your time
If it doesn't drain the water after the wash cycle and the sound is more like a buzz then the first thing that I suggest you check is the lid switch. If the lid switch is damaged then the machine will not pump the wash cycle water out and it will not go into the subsequent cycles. The "grinding" or buzzing sound can be caused by an intermittent signal reaching relay switches or solenoids.
Feb 03, 2011 | Kenmore Washing Machines
Washer makes a steady thumping sound
Could be coin in pump hitting blades...Try pump only no spin this will discount the drum ....Check filter if you have one.
Apr 08, 2010 | Washing Machines
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
Wash cycle is slow and makes slipping sound
If there are 2 belts, change them both. one can get damaged and not allow the other to work right.
Jun 10, 2009 | GE Washing Machines
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
KitchenAid KUDS30IVBT Builtin Dishwasher Logo
18 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
