Question about Sony KP-46WT510 46" Rear Projection HDTV
Have a sony 46 inch rear projection model #kp 46wt510! Purchased it new in 2004! Have nothing but great things to say about picture untill today! I have a color seperation with red, whatever line or picture is showing has red under it! What is wrong with it and is it fixable without major repare?
  • 10,594 Answers
This is problem of convergence output chips failure and it is fixable.
Replacement of convergence output chips on D board will solve tv problem, local tv repairman will do this job because convergence output chips replacement requires soldering work on circuit board.
Thanks.
Posted on Jan 01, 2011
I have a new smart blue ray player and am trying to set it up using a hdmi cable to my sony KP-46WT510 tv and I have video but no sound?
Two things come to mind. !. are your cables plugged in right? Yellow->yellow, red->red, white->white? 2. Is the sound on the TV itself turned up?
Nov 28, 2013 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 Rear Projector TN
Try to hard reset the TV that is Unplugg the device for 30 mins or an hour and then connect it back..It will help you essentially..!..Thank you..
Please post back on how things turned or for further assistance..!..
Regards!!..
Jul 23, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Tv sony 46 inch colored blurry..and picture is bowed
This problem is due to failure of two convergence out ICs in TV that will be replaced to get correct picture.
If you can solder parts in circuit board and have necessary tools to do so, let me know exact model of TV to provide you more technical info or call local TV tech to replace convergence out chips.
Thanks.
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
6 bliks on sony kp-46wt510
KP46WT510 Shutdown 6 Blinks. 6 Blinks = Low B+ OCP/OVP
SOLUTION: Replaced Flyback transformer. It had no rings on the ringer test.
HQ
Comments: Any load on the B+ line can cause 6 Blinks.
Example: If the 200v line is loaded down will cause a drop in B+ due to bright picture current demand.
Click Here! to download the Sony Kp-46wt510 full service manual.
Nov 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
CONVERGENCE IC ADJUSTMENT
My KP-46WT510 picture is out of alignment. There is no conversion of the red, blue and green pictures on the screen. They're off by about an inch of each other.
Some tech told me that it was the power control that was bad. I can see the picture, just very blurred.
Is he right? The tv was not move at all before this started happening.
Oct 22, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46wt510 Convergence issue
convergence ic's replace all 3 be carefull make sure to reapply the thermal compound to the heat sinks after cleaning the old stuff off stk's can be had from global
Oct 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony kp-46wt500 problem with picture
i'm having a problem keeping the timer from going off and shutting the whole tv off.
Mar 20, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
205 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
