Question about Scosche Industries Scosche Build Your Own 12" Subwoofer Box, SE12KT Car Speaker
Popped fuses i installed my new amp and when i turned my stereo on, i got no sound from my sub. when i went to the back, the amp wasnt turned on. i pulled out the 2 30amp fuses on the amp and they were both burned. what couldve happened? do you think it affected my amp? chicanodelchucotx@yahoo.com thank you!
Make sure that the amp is properly grounded, paint somtimes makes it hard for the wire to be grounded, scrape off the paint with a screwdriver or whatever. also make sure that none of the wire are crossed exept if that was done on purpose
Posted on Apr 10, 2009
I get a pop from the sub when the power comes on.
This is caused because the stereo you have put in, is a high power output, or higher than the factory and puts that extra power into the factory amp systems causing the amp to surge the power to the speaker resulting in the pop sound,most newer cars use a stereo system without an internal amp so as to reduce heat and a external amp in usually under a seat or dash and a high power stereo boost the output of the amp.
Sep 27, 2009 | Car Audio & Video
Jvc KD-G210
Did you know there is a fuse on the back of the radio and one on the amp? Have you checked them? If the radio is working and no ssound it could be the radio, speakers or wiring. In your case it sounds like either the radio or speakers.
Sep 22, 2009 | Car Audio & Video
No sub signal from a CDX GT520.
connect the speake(sub) directly to the stereo(just use one of the rear 6x9 speaker wire to test the sub and make sure it's not the amp. if it does not work, it's the sub
Sep 07, 2009 | Sony CDX-GT520 FM / AM Receiver
Noise
that is a bad ground clean exsisting ground or find a new spot where the ground is no longer than 18" if possible
Mar 24, 2009 | Car Audio & Video
Amp won't turn back on, all fuses fine, all connections good
that sounds like the amp might have a bad ground.
Mar 15, 2009 | Kenwood Car Audio & Video
Popping sound! please help - jl 500/1 and two jl w3v3 2ohm subs
no connection are good + to + -to - thats all that matters. either the speakers are blown or you need a stronger amp. since you already tried speakers probably need bigger amp. definitley not the box. no such thing as a break in period, are the subs 10 12 inch or what. you could try to bridge them too that means hook both up to the same +-terminals, 2 wires per screw. it usually isnt the way they hook them up, its the wires fuses etc that cause problems. what guage wires is the speaker wire, the power line etc. if you give me these guages i might be able to get somewere
Feb 24, 2009 | Jl Audio 12W3 Car Subwoofer
Subwoofers not getting music
looks like you need to check the SOURCE of where the signal is coming it could be that your CD car stereo SUB opt. is turn off , check the menu of SOURCE and switch to SUB on , hope this helpful
Apr 28, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Audiobahn A 18001DT
the remote of amp. is not a ground it is a pos.+ 12 vlts look the back of your car stereo red the remote and conect to remote of the amp. if no sign remote of the car stereo conect to the 12 vlts of your bat.
Sep 18, 2007 | MTX Thunder 8302 Car Audio Amplifier
Powers on but no sound
Check the main amp fuse under the hood, even if it looks good just change it. Often times that light on the amp can come on just from the power amp tunon wire. Try a friends subwoofer box just to make sure the connectors on your box are good, and if that doesn't work then give me some more details....year/make/model of car, what kind of sub, what types of things do you see on the side of the amp....is there a green light as well as a red light?
Aug 18, 2007 | Xtant A3001 Car Audio Amplifier
Smoke and no more juice
I Have also had this happen to me, pretty similar around the time it happened to you also, but I'm not just getting my hands dirty and inside the amp. If I fix this, I'll be sure to let you know what it was that I did, or bought and replaced......... I would also like some ideas and support on this if this has already been taken care of
Apr 29, 2007 | Rockford Fosgate T10001 bd Car Audio...
Car Audio & Video Logo
57 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
ravie__s
Level 1 Expert
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
