Question about Brother HL-2040 Laser Printer
After clearing all paper jams, cleaning rollers, etc. my printer continues to jam after the page exits about 2 inches past the "red colored" roller. The jam occurs when feeding from either the paper tray or manuel feed. I tried already the reset option (holding the go botton till all lights come on and press go 5 or even 8 times as sugested by others). Thnaks for the help.
  • coversier334 Jan 01, 2011
    No, no paper is in the machine or drum.
    Sergeant:
    Novelist:
  • 179 Answers
It sounds like you've got a piece of paper blocking the mechanism inside. The only option might be to disassemble the printer and find it.
Posted on Jan 01, 2011
My oki c3400n continual paper jam's at the fuser. Paper comes out of the printer about 2 inches then jam's. I clear it and it happens again. Don't see any contamination on the fuser roller.
There are paper path cleaner sheets that you can get at supply stores or on line. They are sticky on both sides. They pick up paper dust from the rollers as it passes through the printer.
Feb 17, 2016 | OKI Office Equipment & Supplies
Infoprint 1634 repeatedly jams
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
May 22, 2009 | IBM Infoprint 1634 Laser Printer
CONTINUING PAPER JAM. I OPEN DOOR, CLEAR THE JAM, AND PAPER STARTS TO FEED, THEN AGAIN ANOTHER PAPER JAM, AM I USING WRONG PAPER?
I know the problem, Its the Exit paper sensor! if u make a short circuit on the pin 2 and 3 of the CN2 when the paper reaches the sensor it wont jam. Chainging the sensor resolves the continous paper jam or try to clean it!
Apr 08, 2009 | Samsung CLP 315 Laser Printer
Paper Jam
from fixya knowledge base I found this solution
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Let know if working and don't forget to rate solution
Jan 11, 2009 | Brother HL-2040 Laser Printer
Lexmark X6570 printer - Cleared paper jam. No paper scraps visible anywhere in printer. Continue to get error message to clear paper jam and then press the "check" button. Does not reset. ...
Ok, the paper jam could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
First try a hard reset - unplug printer from power source, wait a minute and replug. If it still does not work, uninstall the driver, reboot PC and reinstall (or download latest version from lexmark.com.
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Nov 11, 2008 | Office Equipment & Supplies
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Sep 16, 2008 | Office Equipment & Supplies
Paper jam on back rollers
If it jams every time while printing only 1 page and stops just past the exit of the fuser unit, it is most likely that there is a problem with the paper exit sensor on the fuser unit. We have many of the 1700N printers and have seen several times that the paper exit sensor actuator arm gets broken off when removing a paper jam.
Sep 15, 2008 | Dell 1710n Laser Printer
Phaser 7300N paper jam
Problem:
    The Printer's Front Panel Displays Jam At Top Cover; Open Top Cover To Clear (A7)
Cause:
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. TRY FIRST (Solutions without parts):
1. Unsupported media. - Load supported media and set the media type correctly. 2. Dirty exit rollers. - clean the exit rollers. Paper catching on the duplex guide assembly. - Remove and reinstall the duplex guide assembly. Fuser not fully seated. - Reseat fuser
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers and exit rollers only when dust or
debris is visible.
2. Clean the LED assemblies.
3. Check version of print engine and image processor
firmware; as appropriate.
4. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
5. Review proper operation of printer using a customer
file, if possible.
6. Review with customer all work that was performed; also
discuss how to properly care for their printer.
Rev DT: 01 22 2003
Jan 23, 2008 | Xerox Phaser 7300DN Laser Printer
Printer jam
There is an easy fix for Lexmark E232 paper jams at the beginning of the paper path. This fix only works when the problem is that the paper starts to feed, but does not quite make it out of the paper tray.
The problem is the pickup paper rollers. If you remove the paper tray and press down on the paper indicator (the red lever to the left of the paper tray) you can see the twin rollers attached to a spring loaded armature.
Chances are these rollers are worn and are very smooth to the touch. This slick smooth surface does not have enough friction to push the paper up to the next roller.
To fix this, remove both rollers, they slide off easily. Then simply turn both rollers inside out and replace them on the armature. Notice how much "stickier" they feel now? Chances are your paper jam problems are over, until the rollers wear out again.
At that point you will have to replace them.
Mar 30, 2007 | Lexmark E232 Laser Printer
Brother HL-2040 Laser Printer Logo
96 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
