Question about Sylvania G-Netbook
It won't turn on//battery fully charged - Sylvania G-Netbook
    Genius:
  • 1,267 Answers
Make sure the ac adapter is inserted fully, then flip the machine over on its back and insert a tooth pick into a small hole that is about 1in. diagonally right of the lower right hand side of the data plate. If you look closely in good light you can see the marking RESET. push the micro switch gently holding it for about 5 seconds and a reset should occur.
Posted on Jan 01, 2011
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Aug 16, 2014 | Cars & Trucks
Won turn fully charged battery
How long you have the battery? I suggest you to fully discharged the battery and then charge it as much as you can, do this circle for several times. Hope this can help
Jul 23, 2013 | Fuji FinePix A330 Digital Camera
You sure your battery is fully charged and still good?
on the other hand Sony Cyber-shot's are known to have this problem.
Try pressing the on button for 5sec
Nov 24, 2017 | Sony Cyber-Shot DSC-WX9 Digital Camera
Won't start battery is fully charge. No noise when
Does the engine crank over but not start?
Jan 06, 2013 | Cars & Trucks
Battery will not charge
li-Ion batteries have a bad habit: whenever fully depleted, they lose a few cells, to the extent that they might not be able to hold a full charge if enough cells are damaged. In other words, repeatedly using a laptop (or any other Li-Ion powered device) to battery depletion can shorten the battery's life significantly. You might want to keep the batteries fully charged whenever possible and avoid fully depleting them too often.
There is also the habit of "re-setting" the batteries by using the "fully deplete-fully charge" procedure. It only applies to niMH or NiCD batteries ( and is used to erase the "memory effect" ) but is damaging to Li-Ion batteries for the reason mentioned above.
so if your battery can not full charge,this mean you need change a new battery for your laptop
http://www.aulaptopbattery.com.au
Oct 05, 2012 | Computers & Internet
My battery indicator won't turn green when it is fully charged.what is this issue?
It is possible one of the battery cells has degraded enough the battery is not showing a full charge, or there is an issue with the green light, but this is minor provided everything is working.
Mar 07, 2012 | Acer Aspire One D250 16GHz Intel Atom...
Panasonic HM-TA1 won't power on with battery fully charged.
The battery will not charge when the device is turned on. Make sure that when you connect it to your computer via its usb that you do not turn it on otherwise it wont charge.
The annoying thing about this device is that when you connect it to your computer and turn it on, on the LCD it will say "connecting via usb" and the memory bar will show that it is fully charged, however the battery is not. This must just be a design flaw as the battery won't be charged.
Just remember to plug it in and leave it, do not turn it on!
Jan 24, 2011 | Panasonic HMTA1 Camcorder
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
Sylvania G-Netbook Logo
104 people viewed this question
Top Sylvania Computers & Internet Experts
Mike
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
