Problem for TV Receivers and DVRs
Generic problem for all TV Receivers and DVRs
Digivox DV3 cable box
I have had this box since last october, gradually a few channels have disspeared, last night the date was stuck on 01st Jan 07 so the tv guide page would not work
we tried to reset this aand accidently restored the factory settings, so no channels at all, i rescanned the box and ended up with 200+ channels more than i had in the first place though only ITV 1, 2, 3 BBC 1, 2, 3, 4 and channel. 4 & 5 are working all the others have a $ sign against them and say bad or scrambled channel,
i have read lots of fix's telling us to put in different codes to fix this problem but there is no way of putting the codes in
Can you help please?
Lesley
Same Problem
Nov 27, 2008
-   Hope someone can help! I have found the hidden menu and switched the EMU to on, It was data is updating and moves up the %'s then goes back to 0% again and keeps repesting with no effect. Any suggestions???? -   Guest
Best Solution
posted on Aug 31, 2008
Rank: Apprentice
Rating: 100%, 7 votes
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Was this helpful?1 person thought this was helpful
Solution #2
posted on Aug 06, 2008
Rank: Apprentice
Rating: 86%, 3 votes
You need to Enable the Emulator as this is what clears scrambled channels. Main Menu -Factory Settings enter code 1570 which should give you a new CAS menu. Go down to EMU and switch it on with >vol key. Go up to Negravision and select your area providerer and press OK. Exit and scroll down to Default and hit OK. Will flash "Saving". Exit all the way out.
With certain channels when you first switch to them they may take a minute to upload data automatically.
Good Luck.. Tom (Dublin)
If unsuccessful it is because the code above does not work on your Box. You will know straight away when you enter it if the CAS menu doesnt appear
Popular Solutions for TV Receivers and DVRs
DISH Network DVR-625 DTV Receiver / 100-Hours Video Recorder
1 Solution
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video...
1 Solution
Questions and Unsolved Problems for TV Receivers and DVRs
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product...
(More)
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product woreks? need a powerful Tv receiver to buy.
thankx
how can I use my westell 327W modem as a wireless router? It came with a USB wireless card inside a...
(More)
how can I use my westell 327W modem as a wireless router? It came with a USB wireless card inside a flash drive??
I want to stream my Netflix movies to my TV.
No-one seems to have heard of this model which I bought in Comet three days ago.I am looking for a...
(More)
No-one seems to have heard of this model which I bought in Comet three days ago.I am looking for a user guide which can be read without a telescope!
my screen has faded areas
well i have downloaded itunes but dont know how to put on songs i dont want to pay tho
