Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I threw a chain today on my husky 61 w/20" bar. I
  • 10,865 Answers
Hi moe.... sometimes when the chain comes off it damages the bar or the chain and causes what you are now experiencing. Check the groove in the bar to make sure it does not have a burr or a spot where the chain is too tight. also check the chain to be sure that there is not a bent part. When you put the chain into the bar, it should spin freely, unless the chain tension is too tight.
Once you check the bar and the chain and repair any damage be sure to generously lubricate the bar and the chain. Then be sure that the chain tension is adjusted so that it is not too loose or too tight. When you raise up on the chain in the middle of the bar it should barely clear the bar.
Joe Thanks for choosing Fixya!
Posted on Jan 01, 2011
Barandchainmantaniceon a290
It sounds like the small hole in your bar that carries the oil to the chain is blocked. Start by removing the bar and chain from the saw. Clean around the chain mounting area on the motor block. Take the chain off the bar and clear out the groove in the bar working from the end with the sprocket wheel to the mounting on the motor block. Use a fine stiff 'poker' that goes into the groove and clear all the rubbish out. If possible also blow it out with compressed air. Near the mounting end you should see a small hole on that goes from the outside of the bar to the bottom of the groove. If it is blocked clear it out. Make sure the sprocket turns freely and remount the bar and chain. If you still have the problem then the bar must be wrong for the saw - it could be a Husky bar that has the hole in a slightly different place!
Jan 30, 2014 | Stihl Garden
Tryed to put on a chain cant get it back togather right
Completely loosen the chain tensioner. When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. Fit the chain on the bar.(ensure that the chain travels in collation with the sprocket at the end of the bar if equipped). When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. With the chain still in the bar, fit the 5 or so links in the sprocket on the powerhead, engage the bar with the bar nuts, then lastly engage the chain in the tensioner. Place the sprocket cover and nuts. Tighten nuts then loosen about .5 turn. Adjust chain tensioner. Retighten nuts. See that tightening the nuts made your chain tighter, loosen nuts readjust chain, tighten nuts. With gloves on and the chain brake disengaged please ensure the chain travels around the bar. Put on your chaps and start cutting.
Sep 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Aug 31, 2011 | Poulan 14" Chainsaw
Installation of new chain on 16 " chain
Make sure the chainbrake ( if if fitted ) is off by pulling the hand guard fully back to the top handle, remove the securing nuts and remove the side cover, wind the chain adjuster back if it is in the crankcase, pull the bar fully back, now loop the loose chain off the tip of the bar and over the sprocket, re fit the new chain over the sprocket, and lay it around the guide bar, place the bar adjuster hole onto the adjuster pawl ( if it is in the crankcase ) refit the side cover, if the adjuster pawl is in the side cover make sure it fits into the hole in the bar, put the securing nuts back on finger tight, adjust the chain so as it fits snuggley around the bar, with a gloved hand pull the chain around the bar to make sure it is seated correctly, re adjust if required, lift the bar nose up and fully tighten the securing nuts, after the first ten minutes of use re check the chain tention as there will be an initial stretch.
Jul 02, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to install the guide bar on a chain saw
Most saws are preety standard, pull the hand guard fully back to the top handle to ensure the brake is off, take away the cover nut/nuts, wind the chain adjuster fully back, now remove the side cover, loop the chain over the nose of the bar, and then loop it over the sprocket and off the saw, the bar will now lift away, to refit, place the bar back onto the bar bolts, push it fully back toward the sprocket, loop the chain over the sprocket and lay it around the bar ( the cutters on the top of the bar should be facing away from the saw ) if the adjuster is in the crankcase make sure it locates into the hole in the bar, now refit the side cover, if the adjuster pawl is in the side cover make sure it locates into the bar hole, refit the bar nut/nuts finger tight, adjust the chain so as it touches snuggly all around the bar, with a gloved hand pull the chain around the bar to make sure it is located into the sprocket correctly, re adjust if required, now fully tighten the bar nut/nuts.
Apr 16, 2011 | Ryobi 10" Chain Saw Repl Chain Model P540a
Husky 365 ihave just put a new chain on it cuts perfectly but every now and then the chain jams up with wood the end cog wont turn and I need to pull the chain off to freeit up, any idea's please?
make sure you clean your bar while chain is off..take a feeler gauge like .040 or so the bigger the better and slide it through the grove in the bar all the way around and pull all the crud out then make sure your oil holes in bar are cleaned out so oil will run through the holes into the groove in bar, also if you have an end sprocket in bar make sure it spins freely with chain off,could of been pinched one time or another along with bar, thats why you use a feeler gage to check out bar for being pinched while you are cleaning it out. good luck
Apr 13, 2011 | Husqvarna Chain Saw 20" Bar
What are the steps to replace a chain on a Husqvarna 345 chain saw?
Start by making sure the chain brake is off, pull the hand guard fully back to the top handle, now remove the two 8mm nuts securing the side cover, screw the chain adjuster in the crankcase fully back toward the sprocket, assemble the guide bar over the guide bar bolts and slide it fully back toward the sprocket, now loop the chain over the sprocket and lay it inthe guide bar raiuls and around the guide bar nose, make sure the sharo endge of the cutters on the top of the guide bar are facing away from the machine ( as you loog at it, it rotates clockwise ) now align the hole in the guide bar with the adjuster pawl, re assemble the chainbrake side cover back onto the saw, and fit the bar nuts finger tight, adjust the chain adjuster so as the chain is a snug fit all the way around the guide bar, with a gloved hand pull the chain around the bar manually, so as to make sure it is completly seated in the sprocket and bar rails, re tension if needed, hold the tip if the guide bar up and fully tighten the bar nuts.
Job done.
Jan 23, 2011 | Husqvarna Garden
I lost my manual and need to change the chain on my homelite chainsaw... never had one of these before... stihl and husky are pretty straight forward... this one not so much...
Turn the chain brake off, then remove the side cover (back off the adjustment screw several turns first). Clean the oil ports in the rear of the bar and the area around the oil outlet port. Fit the chain to the sprocket, then work the bar into the chain and pull the bar outward to tighten the chain. Fit the cover back making sure the adjustment tang drops into the large hole in the bar. Run the mounting nuts up finger tight, adjust the chain so that it doesn't droop from the bar, but allows the chain to be turned by hand, then tighten the nuts and recheck chain tension. Hope this helps!
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Chain came off ,need to know how to put it back on!!!
On the chain saw there should be a panel held on by two screws or nuts where the bar and chain is attached. Remove the two screws or nuts and the panel and you will expose the chain and sprocket. Loop the chain around the sprocket and bar. Put the bar with the chain around the sprocket back on the saw, reinstall the cover with the two screws/nuts, but do not tighten too tight.(You will want to be able to move the bar with the chain.) Then pull the bar away from the saw to tighten the chain, once the chain it tight, then you will retighten the screws or nuts to lock the bar and chain in place. Be sure you lube the chain and bar with "Bar Oil" before starting to put the saw into service. Good Luck...I hope this helped Please rate me, Thanks
Jan 04, 2010 | Water Heaters
Husky 460 chains too long (or is the bar too short)
Hello, your bar may not be seating on the adjusting pin properly.Like you I have cut thousands of cords used every saw made and the only time something like this happens is when the adjuster isn't seating properly. Give me your model number and I'll try and round up a manual for you.
Jan 23, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
75 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
