Question about Lowrance LC X-15MT Sonar
Not reading properly
When i get to an area of a lake with a soft btm. the graph will not read the depth or show bottom. Works fine on hard bottom but not soft. Sensetivity does not seem to help. It just started this problem. Any help would be great
You might try adjusting the Grayline setting. It's purpose it to distinguish between hard & soft bottoms. Press MENU, select GRAYLINE, the scale appears like when adjusting sensitivity you can adjust up or down with arrow keys. Get over a non reading soft bottom then adjust. The change is reflected on the screen as you adjust it.
Posted on Aug 29, 2008
Just purchased and Eagle Fishmark 320 used. Will not display depth reading - just shows 0'0"? I have reset to factory settings. We have had in lake,same thing. Right now in 5 gallon bucket of...
Hello! Do you have the PDF users guide for your unit? I'm looking at a copy in the troubleshooting section...I don't want to cover information you have already looked at or tried...Since I do not know if you have that manual I'll give you a few items to check...
Measure the battery at the units power connector...Must be at least 11 volts DC...In portable mode it uses 8 D cell batteries= 12 volts
Make certain the Transducer is securely connected...
Did you use the in-line fuse supplied with the unit?...
Try the Manual Depth Range...First turn off Auto Depth Range...From the sonar Page Hit MENU...Down-arrow to Auto Depth Range...Hit ENT...Hit Up-Arrow to Depth Range...Hit ENT..
And the Depth Scale Range appears...Up-Arrow or Down-Arrow to select a different depth range...Hit Exit...The minimum depth the unit can read is 5 feet...
If you do not have the PDF guide, here is the link...
http://www.eaglenav.com/upload/Eagle/Documents/Manuals/seafinder320df_0143-661_101602.pdf
Let me know how you make out....Guru....Saailer
Sep 11, 2011 | Eagle Fishmark 320 Portable Fishfinder
X105C unit only works in very shallow water less than 10 feet. Every now and then I might get a deep water reading when idle but 99% of the time the depth display just blinks indicating not able to get a...
When my depth finder acted like this I found out it was the sender that had not done well over the winter and was giving me false readings especially when the boat was at speed. The sender and cable only cost around 30 or $40. The hard part was since I have a pontoon boat getting under the Pontoon and replacing the wire in the spring when the water was cold.
Jul 01, 2017 | Lowrance X105c Dual Frequency Sonar
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
My depth finder loses its depth reading at about
You need to set the transducer lower. When at speed, the hull of the ship raises up out of the water and hence your transducer is probably not deep enough at these times to give a proper reading.
Jan 21, 2010 | Humminbird Boating
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
In lakes that are not clear I have trouble adjusting my x96.
This depends on how muddy or clear the water is. If muddy or there is a LOT of floating sediment in the water, most fishfinders will have trouble getting a good image through the dirty/brackish water. You might not be doing anything wrong in this case.
Sensitivity and grayline are your main adjustment settings, assuming you have your transducer located correctly at the right depth in relation to your hull and the waterline as well.
Does the clutter extend all the way from the surface to the bottom? If so, try reducing sensitivty... if clutter is moreso near the surface or top of the screen, then this is probably because the transducer is getting aerated water or distrubed water over it and causing the clutter and readings.
As a good rule, match the sensitivity setting tot he grayline setting. I.e. if you have sensitivity at 90%, put grayline at 90% also.
Hope that helps!
Jun 19, 2009 | Lowrance X96 200khz Fishfinder
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Garmen 240 fishfinder
A test bucket wont work, A 200 khz transducer will generally not work in anything less than 2' of water, due to surface clutter. If the transducer is working, you should hear it make a ticking sound.
When you got the 17000 foot reading was your range set to auto?
How is the transducer situated on the boat? Sometimes turbulence and bubbles from the hull can cause erroneous readings, including unrealistic depths, or no depth at all. Stop the boat and turn off the engin e and anything electrical to see if problem repeats itself. If it only crops up when the boat is moving then it is most likely the transducer location.
Jul 26, 2008 | Garmin GPSMAP 235 Sounder GPS Receiver
Boating Logo
153 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
