Question about GE Spacemaker JVM1640SJ Microwave Oven
Instalation missing screws - GE Spacemaker JVM1640SJ Microwave Oven
  • GE Master
  • 9,047 Answers
You can also download GE owner's manuals and installation instructions here.
You can find handy exploded views and order parts by model number here.
Posted on Jan 02, 2011
I removed the bolts for my Danby OTR microwave. Dmw162w-otr. The microwave does not move. Are there any other bolts or is there anything I am missing before I can remove the microwave?
In a normal installation, there is a plate that mounts to the wall and bolts come down through the cabinet. Once the bolts are removed from the cabinet above mic, the mic should hindge forward. It takes two people to handle. How ever, in some cases an installation guy will add screws into the side of the unit. So look for some screws to the right and left of mic. Good luck!
Jan 29, 2016 | Danby Microwave Ovens
I have a GE Spacemaker Microwave, Model # JVM165OCB006 Serial # TF900232B Manufactured 10/2003. Runs,turntable,light,timer etc but will not heat. Is it worth fixing?
it is mostly fault of magnetron tube inside Microwave. ge has a 10 year warrenty on this part and they can fix it for you for 200$ OR you can order the part from the web and install it yourself. when the magnetron goes out, the diode almost always goes out too so you'll need another of those too. so if you dont want to replace these then buy a new one if not the the steps to repairing are:
  1. Unplug Microwave at least few hours before
  2. Remove Microwave from above oven range by somebody holding Microwave from ground unscrew the screws from cabinet
  3. Remove top cover of Microwave
  4. Make sure to keep screws correctly in a place you remember what goes where
  5. Make sure capacitor is discharged, GE manual inside Microwave says capacitor will discharge within 30 seconds once it is off. As a precaution check the voltage in capacitor to make sure there is no electricity
  6. Remove other panels around magnetron part
  7. You need to remove lot of connecting wires, should be careful to note down what goes where
  8. If possible take digital photos to refer back when you put everything back together
  9. You may need to remove transformer to easily remove and replace Magnetron. If you can't remove Magnetron easily then remove bottom panel of the Microwave and remove transformer
  10. Now it should be easy to remove magnetron
  11. Replace new magnetron and screw it. We had to put one outside part from old magnetron to new one because new one was missing that. Check to make sure both old and new one are exactly the same
  12. Make sure put all wires properly back
  13. Now put transformer back and screw it
  14. Put capacitor panel in place and screw it
  15. This might be a good time to test the Microwave to make sure it works fine now
  16. Now cover the top panels and start to screw everything
  17. Once everything assembled put the Microwave back above range put screws from top
Dec 05, 2010 | GE Microwave Ovens
Need installation bracket screws
You'll probably be able to find the part number either from the installation instructions. You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 14, 2009 | GE Microwave Ovens
Sears Kenmore Microwave Model 401.80086700
Hello
Youcan see that turntable at the down side there is a screw which is missing because i m also having a same problem but now once you change that screw which is losse it will work
Thanks & Regards
May 24, 2009 | Kenmore 80412 Microwave Oven
Spacemaker XL1400
I found a solution for my microwave. Went to Ace and picked up some lag bolts, yellow in color (believe they said it was yellow zinc). Most common seems to be 1/4"-20, but these lag bolts had the smaller thread of 1/4"-28.
I had to go a little shorter in length because the threads don't run the entire length of the bolt. The only downside is that the top of the bolt sticks out inside the cabinet (but only about 3/16"). Well worth it so I didn't have to buy an installation kit that was in the $40-$50 range.
Dec 05, 2008 | GE JVM1650 1000 Watts Microwave Oven
Light went out in Amana Radarange Microwave.
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Nov 21, 2008 | Microwave Ovens
Removal from a motorhome
We regularly repair the circuit boards of microwave which are hit by storm surges, etc.
This repair usually runs $39.95 to $64.95, depending on if we have to replace the low power transformer. I just thought I'd mention this if you're interested.
But if you've decided on replacing it, the installation manual should be helpful in removing it from the wall. See it here.
You will need the free Acrobat Reader to view or print it.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Oct 06, 2008 | Sharp R-1870 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
21 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
