Question about Vizio Televison & Video
Black screen...all else functions - Vizio Televison & Video
  • msquared63
    msquared63 Jan 10, 2013
    what if it doesn't have LED backlights mine has tubes and 5 of them are broken where can i find replacments tubes
  • Cindy Wells Jan 10, 2013
    The compact fluorescent tubes can be obtained fromhttp://www.lcdparts.net and other shops. LCDParts also has LED replacements for some size monitors. You will need to measure the current CCFL tubes to get their exact length and diameter. If you look on the left-hand side of the page at lcdparts.net, they have the organized their products so that you can easily search by the monitor type. I hope this helps. Cindy Wells (The diameter is the most critical size; the lengths tend to be the same for any given monitor size.)
  • Vizio Master
  • 5,165 Answers
It's probably a backlight or backlight inverter issue if the problem occurs on all sources and the onscreen menus. (The backlight itself usually fades or makes the on-screen image change to pink/red.) With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing. For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.) The scorch mark and smoke may indicate a resistor or zener diode that had been used as a fuse and is now gone.
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the inverter board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Separate the panel from the bezel. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. See http://www.lcdparts.net/howto/default.aspx for more information but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx. Then push the new backlights into place, reconnect the wires and close up the sandwich of tape and other parts around the screen. Then replace it in the bezel.
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight.
I hope this helps.
Posted on Jan 01, 2011
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
Laptop is on but screen is black
Try an external screen. That will exclude the motherboard. Shine a bright light at the screen, if you can see a picture, the back light has failed.
Dec 30, 2013 | Toshiba satellite c660
Toshiba laptop black screen
on boot go to setup, make sure you have display set to LCD and not external monitor, if still a problem after boot, wait for windows sound, hold function key down and press the F4 key (or what ever function key looks like it has a monitor /lcd symbol on it, mine is the F4)
Jul 08, 2012 | Toshiba C665 15.6/i5-2410/w7pr
Black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
Mar 28, 2010 | JVC AV-32D305 32" TV
IXUS 70 with black screen!
Did you accidentally press the lower-left DISP button on the back of your camera? This manually turns the screen on and off to save battery power. You would then use the optical viewfinder in its place. Try pressing the DISP button once to see if the screen turns back on.
Jun 20, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens & screen show black instead of item to be shot.
You need to go into the menu function to turn the screen on (this feature saves the batterys)
Dec 08, 2008 | Cameras
Compaq Presario V3010US not working properly - screen stays black and computer not functioning properly - battery instantly hot as soon as you try to turn on - Already replaced motherboard due to fan not...
Dropped computer and screen is not working (just black). Other lights on computer ar coming on. Tried to hook up to an external monitor and it does not work.
Sep 22, 2008 | Computers & Internet
Televison & Video Logo
166 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
