Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
It is self propelled and makes a screeching noise when I use it?
  • 294 Answers
SOURCE: Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Posted on Feb 28, 2009
SOURCE: toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Posted on Mar 18, 2009
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
  • 61 Answers
SOURCE: adjustment for self propell speed?
no adjustment for drive
Posted on Apr 29, 2010
rickead1
  • 1998 Answers
SOURCE: electric dryer makes a screeching noise while
could be your pulley or rollers or the motor itself you have to take the entire unit apart and visually inspect where the noise is coming from could be rear bearing if the model is old enough if you are not mechanical i suggest you call a tecnician hope this helps
Posted on Jul 15, 2010
My Hoover self propelled 900 making a terrible noise.
could be patially clogged and/or belt could be starting to rip.
Oct 10, 2014 | Vacuums
Self propelled clicking noise
check the cable that connects from the handle to the power drive. you might have broken a fastener between the two.
Dec 26, 2012 | Vacuums
I have the Hoover, self propelled vacuum. I have only used the self propel function a few times, but our babysitter used the feature and now the vacuum only works on the highest carpet setting. The middle...
Move the carpet height control switch to a higher position if the vacuum is difficult to push. If the setting is too low for the carpet being cleaned, the brushes press against the floor preventing the vacuum from moving easily.Set to a medium-high height setting then check.Slide the "Self-Propel" button to the "ON" position if the cleaner does not self-propel. -----------
The self-propel feature operates only when the cleaner switch and the self propel button are both ON. ---------- Try this settings and check.This should help.Thanks.Helpmech.
Jun 24, 2011 | Hoover Self-Propelled WindTunnel Bagless...
My Dyson Absolute has started making a loud noise and the has gotten progressively more difficult to push. I'm guessing the self-propel has stopped working. Is there a quick fix?
Hi its Darran at Dyson.
Try making sure the brush bar is turning when in the vacuuming position. It is possible that the brush bar is obstructed which can cause your machine to make this noise.
Check out our online help at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service.
Apr 13, 2010 | Dyson DCO3 Absolute Bagless Upright...
Self propel unit broken
This is a farily common repair on this model. What ends up happening is that when someone picks up the vacuum cleaner2_bing.gif by the handle of the machine, which on this model also is the controller for the self-propelled transmission, it places too much strain on the actuator arm of the vacuum2_bing.gif cleaner.
You can do the best to try and not pick up the machine by the handle, but instead using the carrying handle on the back of the vacuum cleaner, this is distribute the weight much better, and even make the machine seem less heavy, and this will also prevent the actuator arm from breaking again in the future.
Now for fixing your vacuum, Please click the link below for an excellent tutorial on how to replace this part;
How To Replace The Actuator Arm On a Self-Propelled Hoover Windtunnel Upright Vacuum
Feb 23, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Windtunnel self-propelled feature broken
If it is a rubber smell, then it could be belts and/or brush roll. If it is an electrical smell, then it could be the motor. Take the belts off and see if it still makes that noise, if it does, then the motor is going bad.
Apr 22, 2008 | Hoover Self-Propelled WindTunnel Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
130 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
