Question about Casio Watches
Instructions for mounting band for g force mtg960 by Casio
  • 76 Answers
Search it on internet,go for google search with full details about the product
Posted on Jan 01, 2011
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
Hello I need to set my 4777 onto London time, Thank you Simon
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Oct 31, 2010 | Casio Multi Band Atomic #GS1100 1A Watch...
How do I adjust a Casio PAW 1200 Titanium watch band.
You can get instructions from the Casio web site.
Select "support" and the "manuals", watches;
Accept terms
Click on "search" and the download your instructions.
Feb 26, 2010 | Watches
Im tryna find out what dynex big band tv code for a casio watch remote
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps.
R/
David
Jan 03, 2010 | Casio CMD30B Watch
Casio prt-10 and i broke the display. where i can buy lcd?
You're probably going to have to replace the complete guts. Lots of these digital watches have the little buttons on the sides of the case. Those buttons press small springs which makes contact with the button on the "movement". Be careful that the little springs aren't lost when you remove the movement. It's not hard to do, you just need the right parts. A small phillips screwdrive and a sharp probe makes things easier.
In some cases, you will need to force the stainless steel back past the rubber wrist band. These watches are nearly indestructible, so you can apply some force. Just don't apply it to the guts of the watch.
Jun 14, 2009 | Casio G3011 Duplex LCD Watch
Casio G-Shock GW-300 replacement bands
I have a Casio g-shock gw-330a and now find myself again replacing the band. So far, $60 on bands. They last me two or three years. To install the band, take the band and watch to a Jeweler. My local Sears does it for me. $5 for installation; $5 for purchase shipping; $20 for band. $30 every couple of years.
This cost disturbs me.
Jun 09, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
How to change the time
You can find the instructions at this web site http://www.casio-europe.com/euro/watch/collection/aq-230ga-9dmqyes/ :)
Jun 05, 2009 | Casio Analog Digital 2 Time Silver Metal...
Remove few pieces in my Casio AW-SD bracelet
What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
Jun 07, 2007 | Casio AWS90D-2AV Wrist Watch
Casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Dec 17, 2006 | Casio G-Shock G7000D-8V Wrist Watch
Watches Logo
61 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
