Question about Health & Beauty
Hi. Need user's manual for the CardioZone 300 compact adjustable stride (center drive) elliptical machine. Name is James S. email: jamessantiago1@hotmail.com
    Problem Solver:
  • 12 Answers
Check your email, I sent you one.
Posted on Jan 01, 2011
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
I receivd bh elliptical ocean program with no power cord.The sticker on trainer is torn,it has 6v but thats it. Googled & found nothing on Power cords or power sup needed to turn on thanx again,kirsti
It could be that the BH elliptical you have does not need an external power supply, but it does need a new set of batteries in the console.
For example:
The X8 BH elliptical is self powered, when a user strides at a speed about 20 RPM's; electricity is generated to allow the console to function properly. Exercising recharges the batteries in the console.
If you want to take a look at the X8's manual as a reference to see where the batteries are located in the console you can check it out here http://www.gophersport.com/files/pdf/GS68997_BHFitnessX81.pdf
We hope this helps in any way :) if you ever need a little help trying to figure things out you can chat with us at www.sportsmith.net or by phone at 888-713-2880
Apr 14, 2015 | Exercise & Fitness
What is the typical stride length in an elliptical machine?
Generally,you should look for an elliptical machine with 18-21 inch stride. Anythingunder 18 would result in an uncomfortable workout.
Aug 05, 2012 | Exercise & Fitness
Can you adjust the stride length on an elliptical training machine?
Some machines are sold with the capabilities to adjust stride length; which is a great feature if the machine will be used by more than one person.
Aug 02, 2012 | Exercise & Fitness
I want to buy an elliptical trainer for our home gym. What features should I be looking for before purchasing one?
The following are some features you should be looking for before purchasing a machine for your home: the stride length of the pedals, smooth motion of pedals, the option of arm handles, adjustable incline and resistance. You may not want all of this in one machine; however these are some qualities you should be addressing.
I have Life Fitness X3 elliptical machine, and when I start pedalling/striding the level setting goes to
adjust the magnet, tight the bolts with wren. Test the magnet, with the magnet from refrigerator, for repel and attract, if donot, replace.
The resistance depende of it.
sincerely. God bless you
May 06, 2012 | Life Fitness X3 Elliptical Cross-Trainer...
I have a commercial cardiozone elliptical cg3 500 with automatic stride adjust. The elliptical is giving an err 2 message when we try to use it. Restarting the machine does not fix the issue. How do we...
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of thepedals to the crank axles.
Good luck, sincerely.
Aug 24, 2011 | Cardiozone Supersport Hr Club Commercial...
I want to convert the distance/speed from miles & mph to km & kph to assess the distance and speed after running?
Manual is here: http://www.sportline.com/manuals/370.pdf
SETTING USER DATA The Sportline TraQ is equipped with an advanced Pedometer that measures Steps, Speed, Distance, Calorie Expenditure and Exercise Time. In order to ensure exercise data is as accurate as possible, you must enter your personal profile. 1. Scroll to User Data (display will read AGE) by PRESSING the MODE key. 2. PRESS the RESET key to enter the programming sequence. 3. Adjust Age by PRESSING the INFO key. PRESS the MODE key to Advance to Set Weight. 4. Select Weight Units (LB or KG) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 5. Select Units of measure (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 6. Select Stride Length Units (INCH or CM) by PRESSING the INFO key. PRESS the MODE key to Advance to Set Stride Length. 7. Adjust WALK Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set RUN Stride Length. 8. Adjust Run Stride length by PRESSING the INFO key. PRESS the MODE key to Advance to Set daily step GOAL. 9. Adjust daily step GOAL PRESSING the INFO key and advancing to next digit by PRESSING the MODE key
Jan 02, 2011 | Sportline 370 Traq Motion Sensor Pedometer...
Health & Beauty Logo
62 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
