Question about Franklin Rocket eBook
I have an old er EB 500 USB that was used on my desktop.I stored the unit away until recently I found it. Howevr I cannot use since I only have laptops. Is there an USB connecter that is available? Joe
Hello, no recognize media expansion bay
I found a list of the needed drivers most of them have drverguide.com registration is free:
VGA
Intel 82865G Integrated Device
AUDIO
Intel 82801EB ER AC97 Audio Controller (ICH5
ICH5R) Device
NETWORK
Realtek RTL 8139 8139C
MODEM
Conexant Rockwell HSF 56k HSFi
FIREWIRE
VIA Fire II OHCI Controller VT6306
DEVICE RECEIVER
Logitech LX 700
MULTIMEDIA ENCODER
Conexant Rockwell CX23418 Single Chip MPEG 2
USB
Genesys Logic USB Hub DUB H4 USB Hub
and
Intel 82801EB ER USB2 EHCI Controller ICH5
ICH5R
WI-FI
Belkin Ralink RT2573 F5D7050 Wireless V3000
Jul 03, 2014 | Acer Aspire RC500 PC Desktop
What program do I use to open the backed up files?
What ever program you used to back up the files in the first place.
Did you use windows, or a different program ?
Are they stored on this
Verbatim 500GB USB Desktop 500 GB Hard Drive ?
When you use a program to backup a operating system, the program has the option to restore the system.
If you copied files onto another HDD, then you just copy them back.
You need to post what you used to do this.
Apr 13, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
My explorist Gc unit...on start up is looking for an active tracking file which is missing. I have a copy on my desktop. How can I get it back into the unit?
You can download the US basemap for the 500 at
http://www.megaupload.com/it/?d=EJTNQH03
Rename it BASEMAP.MGI
Then copy it in the directory "background maps" in the SD card of your 500, by using a SD card reader/writer.
Insert the SD card in your 500 and connect it to your PC; then turn it on;it will turn on regularly, because the basemap in the card will be detected; turn it to USB file transfer mode, and copy the basemap from the SD card to the directory "background maps" of the 500.
If you already have the file ..just rename it like I said ..and copy it ..using the sd card in the reader...Than if it is not functional ..just reset it ..and reload the file the proper way by reloading maps..
Aug 28, 2011 | Magellan eXplorist 500 GPS Receiver
How do I save memory on my mini and save files on my iomega
Attach the cable from the external hard drive to an available usb port on your mini. Here is a link to the Guide provided with the unit if you do not have it. There should be a setup section. Use this drive to store all your pictures, music, documents etc.
Mar 10, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Fitted replacement er 500 engine to my kle500 and it dose not start
DID THE ER ENGINE RUN BEFORE?.ARE YOU GETING A SPARK AT THE PLUG? YOU MUST REMOVE THE ORIGINAL GENERATOR AND OR TIMING GEAR FROM THE OLD ENGINE AND FIT IT TO THE ER ENGINE,CHECK ALL WIREING IS CONNECTED CORRECTLY INC EARTH WIRES, ANY OTHER HELP FEEL FREE TO EMAIL ME
Oct 27, 2010 | 1991 kawasaki KLE 500
I AM AMONG THE MOST DISORGANIZED PEOPLE IN THE WORLD! I NEED A SPECIFIC DESCRIPTION OR IMAGE OF A SEAGATE 500 GB FREEAGENT DESKTOP USB DRIVE POWER SUPPLY SO THAT I MAY DIFFERENTIATE IT FROM THE LITERALLY...
Hi a 500 GB ( Gigabyte) is an hard hard drive is could be for laptop or desktop so it depend on the computer you have.USB drive is a little device about three inches long and one inches wide it is use do store data by plugging it into the USB port on the computer. Power supply is the square device which supply the whole computer with power,it has many wires with connectors at the end of the wires,and most connectors has four pins except the one which connect to the motherboard,because it can have either 20 or 24 pins. If you have any questions please feel free to ask me
Jul 27, 2010 | Computers & Internet
The box super usb
hi got a starview the box super usb, lost all discovery and music channels. can you help
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
ITunes or sound card line in with my USB Plantronics DSP-500 headset
Recently on an HP desktop computer I found setting the device in the Sounds and Audio Device Control panel Voice Tab (and possibly Audio Tab) to reduce the issues with the device ceasing to work. Setting the device from the Sound Icon in the System tray recently only a very temporary fix where the settings reverted to the Sounds and Audio Device Control panel settings in at most minutes. This is at best an I hope it helps solution as I do not know your specific hardware and software configuration we cannot test a solution.
Jan 04, 2007 | Plantronics DSP-500 Headset
Franklin Rocket eBook Logo
Top Franklin Computers & Internet Experts
Andrew Taylor
Andrew Taylor
Bill Boyd
t d
t d
Level 1 Expert
Are you a Franklin Computer and Internet Expert? Answer questions, earn points and help others
