Question about Star Logic Monitor
The monitor displays a "out of range error" after
  • 11,361 Answers
You mean the refresh rate is 60 Hertzs not 60 million Hertz (too high rate can damage the monitor).
You are getting the message because the PC video resolution is too high for the monitor to display, you need to set it to the native resolution of the monitor.
Read more here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 01, 2011
I am putting my old computer (Dell XP) in garage to use strictly to view files, play dvd's/cd's, etc. It is not going to be used to go online to internet. I hooked up...
Hi there.
You'll need to adjust the refresh rate. I have recently written a tip on adjusting a monitor's refresh rate. I suggest you give it a read and let me know how it goes.
You can see my tip here:
http://www.fixya.com/support/r9352855-adjust_or_change_monitors_refresh_rate
Enjoy my tip.
Slasher_X
Sep 24, 2011 | ViewSonic VX1935wm LCD Monitor
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
WHEN I START PLAYING TOTAL OVERDOSE IN MY WINDOWS XP A BLACK SCREEN APPEARS AND SHOWS "OUT OF RANGE:" PLEASE PLEASE HELP ME
yes minamino kitagami is right,
goto start menu ,
select Run
type in "dxdiag"
DirectX Diagnostic Tool will run
then click at "More Help"
you will see there Override tab in last just click it
after that "Refresh appears"
set it from default to override rate "60"
now exit.
and play the game enjoy.
Mar 21, 2011 | SCi Total Overdose for Windows
I installed the game whenever i open it i get Remark on monitor Out of Range. 53.5khz 85hz
That error message means the game uses a screen refresh rate that is beyond or below what your monitor can display.
You must find the game option (setting) somewhere in the game and change it.
60 hertz to 75 hertz is normal for most monitors.
Mar 17, 2011 | Computers & Internet
Refresh rate will not switch to 60 hertz from 59 hertz. Hence my hdmi connection from my desktop to my display keeps showing "out of range" error
turn off the computer restart it and press F8 immediatly before start and keep pressing untill menu appears then highlight on" enable vga mode" and press enter your problem will be solved
Apr 05, 2010 | Westinghouse 25.5" Widescreen Flat Panel...
Frequency out of range
Try to set the monitor refresh rate to Adapter Default despite of Optimal or lower rate of refresh. For this first download the manual of your monitor and check what is the highest refresh rate your monitor can suport. Then goto the display properties and set the adapter refresh rate to Adapter Default. In most cases such problem is solved. You did not mentioned the OS. This method is applicable in Windows only. (ehteshamhusain@gmail.com)
Jul 23, 2009 | HP Compaq FS7600 17" CRT Monitor
Showing message out of range
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Feb 18, 2009 | Dell Dimension 8200 PC Desktop
Monitor out of range when a game is booted up
The maximum resolution for the MV540 is 1024X768 @60Hz refresh. The other monitor isn't giving you an error message because not all monitors have that feature, but both the monitors are unable to display whatever data the computer is sending. If the display is normal until you start the game, then the game itself is setting the resolution to something out of the monitors' range. You'd need to set the game up to play at a setting the monitors could handle. I've never played WoW so I have no idea if the game offers a way of selecting the resolution. The game may simply require more graphics capability than your monitor can provide. Most systems now are using 17 or 19-inch flat screens or CRT's, and they offer more resolution and refresh rate options.
Jul 29, 2008 | Compaq MV 540 15" CRT Monitor
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Star Logic  Monitor Logo
204 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
scj103
Jerry Umali
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
