Question about Refrigerators
HOw do I turn ir off? - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
The best thing to do is to pull the plug...
heatman101
Posted on Jan 01, 2011
Before I start to desolder and solder an new IR component I have a question. The green led doesn't turn on, but why does the interface module turn on when I disconnect the White and Red RCA plugs? So,...
It is probably not the IR component. It sounds more like some voltage problem between components. Can you narrow the problem down to which RCA cable and then down to the component itself? It almost sounds like the system is preventing a failure by disabling the IR component.
Mar 17, 2015 | Bose CineMate Speaker
M420mv vizio led television ir infrared doesnt work
that can be caused by either the IR sensor board or the main board. The IR sensor board would be suspected first. You can get the IR board or the main board from www.tvrepairworld.com
Feb 09, 2013 | Vizio Televison & Video
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
I bought a Night Owl Vision Cyclops 1 monocular marked Made in Russia from a man last weekend at a flea market. It is in pristine condition and the gentleman said it worked but he hadn't used it in a...
Hello, Is there two switches on the NV monocular? If so, one is for the IR illuminator and other is for turn the scope off/on. Also, does each switch have a LED associated with it? Green for turning on the monocular and red LED when the IR illuminator is on. Now the IR switch is a momentary switch once you push on the button it turn on IR. If you release the IR button it turns off the IR..
What do you mean by green lightening storm in the view finder? Generation 1 image intensifier tubes when ignited by 15KV it will glow green in the tube. If you look through the eye pieces there will be a green glow with fluctuating intensity as bright light impact the plate in the image tube. GB...stewbison
Aug 22, 2011 | Kalinka Zenit NV CH Russian Night Vision...
Need the codes for a sony tv
Hi, Cheri Torres with DISH Network Customer Service here. We have a few different codes for each of our different models of remotes. The model number will be located on the back of the remote at the top usually a two to three digit number with a decimal point. I will list here for you the best codes for Sony TVs as well as the instructions for addressing the remote to the TV. I hope you find this information useful and if you have any further questions or concerns feel free to email me directly at Cheri.Torres@Dishnetwork.com.
Codes for Sony TVs
3.0, 3.1, 3.2, 3.4 IR remotes - 500, 000, 590, 640, 766 and 837
5.0, 5.2, 5.3, 5.4 IR remotes - 500, 640, 514, 810, 758 and 578
4.0 and 4.4 IR/UHF remotes - 500, 000, 590, 683 and 837
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - 500, 640, 683, 758, 590 and 837
20.0 IR and 21.0 IR/UHF remotes - 781, 500, 611, 837 and 590
Instructions for address the remote to the TV
  1. Turn the Television On.
  2. Press and hold the TV mode button until all other mode buttons light up red.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press the pound(#) button once. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
May 23, 2011 | DISH Network IR Remote Control
DISH Network UHF/IR Remote Control: switch 21.0 remote from uhf to ir...
There is a key in the bottom that has number 2 on it . Turn the key over to number1 and slide the button under the battery cover if needed from a to b or vise versa
May 18, 2010 | Universal Remote Control DISH Network...
Why does my TV not respond to any remote, not even the original remote control. I'm unable to turn on or off or change channels. (Proview 3200)
It can be IR receiver is not working or the CPU is getting the signal from IR board but not processing the signal properly, you can try new IR receiver board.
http://www.shopjimmy.com/led-ir-assy-200-500-hx276-from-proview-3206.htm
Mar 13, 2010 | Televison & Video
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
It turns itself on and off repeatedly
Try this:
Unplug the tv let sit for a minute while you replace the batteries in the remote and cover the IR remote sensor on the front of the TV. Cover it with a piece of black tape or a piece of aluminum foil.
Plug the tv back in and turn on.
If it no longer turns on and off by itself then you have IR interference from some other remote operated device in the room.
If it does continue to turn on and off with the IR sensor covered then it is the internal wiring/processors and will need servicing.
May 12, 2009 | Sanyo DS27510 27" TV
1934 model recieving
cthy_prry,
The IR detector is in your TV set. It is the device that picks up or captures the IR signal from your remote control and turns it into an electrical signal that the TV via a processor interprets as a function or command to have the TV perform in a certain way as turning on, channel up or down, volume up or down, etc.
IR means Infrared
I hope this answers your question.
Thank you,
Shuttle83
Aug 19, 2008 | Orion1934 19" TV
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
