How can i install a game controllers drivers for free and how does my USB gamepad controller works with it?
    Genius:
  • 1,288 Answers
Most game controllers are plug and play anyway, you simply need to calibrate them in the control panel by clisking on the controller icon and following instructions.
Posted on Jan 01, 2011
Its not working but the computer does recognise the controller.
You need to calibrate the controller. Go to the Logitech website and install the latest drivers. This will include software which allows you to recalibrate your controller.
Hope this helps.
Jan 24, 2011 | Logitech Precision USB Gamepad PC Game...
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you sitek.com itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Trying to install Gravis Eliminator Gamepad Pro/USB under Windows XP SP3. When i plug it into a USB port, I get the Windows message "USB Device Not Recognized". If I go to Control Panel > Game...
I have encountered a similar issue before. What works, is to try the update of your chipset's driver. This could be an error once present in your chipset's initial release, but has since then been fixed by your chipset's manufacturer. Also this could another among the millions of peculiarities in the windows operating system, i say this for it is very possible the the controller will function well if a game is started while the controller is already plugged in. Just see if it works, but an amendment to the chipset's instruction set would be optimal.
Jul 20, 2009 | Gravis Eliminator GamePad Pro Game Pad
USB GAMEPAD NOT WORKING!!!
I used one like that for my windows xp home PC (It looks just like the Playstation 2 controller) and it worked with MAME (original arcade games that were downloaded on my computer) It comes with a little CD that has the drivers on it...Look on ebay..they are very cheap coming from China and Hong Kong
Apr 24, 2009 | Video Game Consoles & Games
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Problem with gamepad
Unfortunately, I am unable to find any Vista drivers for this gamepad. However, it should be supported natively. Try going into 'game controllers' in the control panel and see if you can set it up from there.
May 22, 2008 | Video Game Consoles & Games
LOGITECH PRECISION USB GAMEPAD
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Cheers!
Apr 14, 2008 | Logitech Precision USB Gamepad PC Game...
Gamepad wont work
game pad is need to install in to yr pc 1 u have to install drivner then u plug yr gamepad to usb pord
thnaks
jo_chinmay
Apr 02, 2008 | Logitech Rumblepad 2 Vibration Feedback...
Computers & Internet Logo
88 people viewed this question
David Payne
David Payne
