Question about GE Ovens
What size wire do I need for a ge profile 27"
    Sergeant:
  • 223 Answers
Well, 6800W/240V = 28.33 amps, call it 30. Minimum AWG wire size 10ga., if you're running it over about 20' go up to a 8ga. to be sure your oven is fed adequately.
lp
Posted on Jan 01, 2011
++thermal fuse location
Wiring verified correctly? Or could be a dud from the factory.
Mar 03, 2014 | GE Ovens
I will soon purchase a GE Double Oven (no stove top). I need to know what amperage I need to wire my kitchen for. 30? 40? 50? thanks.
A full upright range including 4 hotplates, oven and grill elements is generally rated about 8.0 to 10.0 kilowatts. The normal circuit in Aust. is a 32 amp circuit. Check the kilowatt rating of the double oven but I don't think it will be any higher than 6.0 kilowatt. If so the 30 amp circuit will be fine.
Feb 18, 2011 | GE Profile JTP56 Electric Double Oven
How to install GE JKP35DPBB 27" Double Electric
The specs for this double oven give a rating of 5.1kW at 208V so it needs a 30 Amp circuit breaker. This assumes that the oven is the only appliance on the circuit. So you should be able to use the same circuit breaker.
A bigger consideration is that the opening for the double oven needs to be larger than that of the single oven. If the opening does not have a solid bottom, it must be able to support a heavier load. The runners and braces under a single oven has to support 200 pounds (91 kg). A double oven must have braces and runners designed to hold 375 pounds (171 kg).
Also check if your household uses aluminum wiring. The new oven has copper and problems will occur at the interface if you do not use the appropriate precautions. (Products designed for mating copper and aluminum are available - follow the directions).
I hope this helps.
(btw: you can find the User's Guide and Installation manual for the double oven at GE's website: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=JKP35DPBB . See the section Literature and Manuals on the left hand side of the page below the picture of the oven.)
Oct 29, 2010 | GE 27" Built-In Double Electric Convection...
Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
Jun 18, 2009 | GE Profile JT912 Electric Single Oven
Installing ge profile double oven not convection in new build trying to find out electrical requirements ( size breaker 50,60amp ?)
You must use a three-wire, single-phase A.C.
208Y/120 Volt or 240/120 Volt, 60 hertz
electrical system. If you connect to aluminum
wiring, properly installed connectors approved
for use with aluminum wiring must be used.
That means that you ned a double 40 amp breaker.
Good Luck
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
Ge oven install
go ahead and wire the blk to blk and the red to the white as long as the data plat on the old oven say's 220 you should be ok
Dec 26, 2008 | GE Profile JTP56 Electric Double Oven
Ovens Logo
130 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
